diy oil change...
diy oil change...
I plan on doing oil change myself as i did on my 07, checked the garage/service dept for a diy, but there isnt one...
havent looked the car over yet, but is the oil filter in the same spot as my 07? anything different that i need to look at before i do an oil change...
thanks guys
thanks guys
its not a true "crush" washer as it doesnt compress as you torque the drain plug, so i dont see any real reason to change it...i think i got one at the local honda dealer for free the one time i replaced it...
COTM Coordinator
It doesn't "crush" like a crush washer, but it does compress because it is a brass washer. Made to form to the imperfections of the mating surfaces. Yes, you should replace them every time as a preventative measure.
It's aluminum and you should replace it each time. Like Murky said, it conforms to the micro surface irregularities. Probably you'll get away without changing it but they only cost like 25 cents each so why risk a micro oil leak?
COTM Coordinator
6000 Miles
I plan on doing oil change myself as i did on my 07, checked the garage/service dept for a Doy, but there isn't one...
haven't looked the car over yet, but is the oil filter in the same spot as my 07? anything different that i need to look at before i do an oil change...
thanks guys
thanks guys
I got a coupon for Oil & filter change, under hood inspection, wash car, top off fluids AND rotate the tires for $69.00. I appreciate doing your own oil change, done that for years, but the tires should be rotated every 5K or 6K and I rather have someone else do that. Oil Indicator still tells me I have 40% life on the oil, but if I waited till it told me to do a service, it would be a year at least based on my 10K per year driving. Oil consumption was 3/4 of a quart the first 4K miles but for the last 2K miles, zero oil loss. Oil looks dirty now so in it goes on Friday!
Hope your self oil change went OK?? Let us know!!
IBankMouse
06-13-2020 12:53 PM
