Hello all,
Just purchased a 2012 TL Technology Package. Replaced the stock 17" wheels with 2012 18" from a base 2012 SHAWD. Color is White Bellanova White Pearl.
I would like to pull the trigger on a set of cross drilled and slotted rotors. I was curious if anyone had installed the 2012 Disc Italia units?
Thanks,
Thanks,
Can't seem to find any good reviews on the Disc Italia cross drilled and slotted rotors for the 4G. Found a few older reviews that complaint about rust. These new ones are nickel plated so I guess that means no rust?
http://www.brakeworld.com/ProductLis...m=ACURA&mod=TL
BEAR-AvHistory
close
- Join DateSep 2006
- LocationRaleigh, NC - USA
- Age84
iTrader Positive Feedback0
iTrader Feedback Score(0)
Liked:2,600 Times in 1,581 Posts
I put Brembo cross drilled on my 3G with good results, any available for the 4G?
I have looked for the Brembo but nothing available for 4G. It has been a while since I owned a TL. It seems like the aftermarket is not what it was for the older gen.
Former Sponsor
We offer a STOPTECH Brake Package for the 09-12 TL. It includes STOPTECH drilled/slotted rotors and STOPTECH ceramic pads.
http://store.excelerateperformance.c.../i-466577.aspx
These Acurazine brake packages are designed to improve braking performance and durability at a reasonable price. The packages include Powerslot/STOPTECH performance rotors and STOPTECH Performance pads. All of the rotors have a black e-coating on the hubs and vanes and an advanced alloy composition. The Powerslot slotted rotors for the front of most Acuras also have a Power Alloy composition and a curved vane construction, which helps reduce heat in the brake system. The STOPTECH Performance pads are a para-aramid compound, which has great initial bite and long-term performance and lower dust and noise than most aftermarket brake pads.
Steven Bell
close
- Join DateJan 2008
- LocationKansas City, MO (Overland Park, KS)
iTrader Positive Feedback100
iTrader Feedback Score(2)
Liked:6,470 Times in 5,162 Posts
I might get these when I need rotors myself.
