Directions on installing roof spoiler
I have searched the forum and can't find anything on this. I received my roof spoiler from oembmwshop on eBay this week and want to install it today because there is no rain expected this week.
The package did not include any directions for installing and it didn't include the glue.
Two questions:
Two questions:
- Is the glue needed? If so, will a silicone glue of some kind work? Any direction on what to buy here is appreciated.
- Does anyone have a PDF of the installation instructions? I can make some assumptions, but want to make sure I get it right the first time.
I am thinking about purchasing this also. Here is the link, most of the information is on page two.
https://acurazine.com/forums/showthr...spoiler&page=2
Two questions:
Two questions:
I noticed the right side lifting up so I wanted I start over.
Here is what I would recommend. Do not use the glue. It did absolutely nothing and was an absolute pain to remove from my glass. Most of the glue I applied never even adhered to the glass and just stuck to the spoiler itself.
The tape included with the spoiler is weak. I'm either purchasing some 3M moulding tape or I may even wait and order 3M vhb tape.
I peeled all the existing tape off and scraped off all of the glue residue from the spoiler. I'm planning on adding 3 strips of tape instead of the two when I reapply it. I would suggest doing the same because the tape it shipped with was just not strong enough.
Also, I think it was too cold when I applied it (about 50 degrees) so I'm planning on heating the garage until the ambient temperature is at least 70 degrees.
This is just my experience and ymmv, but I wanted to share my experience.
I purchased mine from the same eBay seller you did.
Good luck.
I just bought some aquarium (silicone glue) at home depot and it says it adheres to rubber and glass.
I'm about to do it, so hopefully it will work. I'm not the best at this stuff, so we'll see how it goes.
Hogan, sorry I couldn't get back to you sooner. I just put 2 layers of the 3M tape on top of each other and did not use any glue. I'm sure what you did will work fine!
The roof spoiler I got off ebay did not come with any glue. It came with some type of chemical to prepare the glass for the tape. Once I put the chemical on and let it dry, the tape stuck the wing down very tight. Its been on for 8 months, and it still very snug on the rear glass. It would be be very hard to take if off. That chemical helps the tape stick better on the glass.
I also got mine from ebay a few months ago..
I used the glue it came with and also the 2 strips on the top and bottom of tape that was supplied on the spoiler itself worked perfectly for me..
Its been about 4-5 months now and nothing wrong with mine..came with directions also
takin care of Business in
unlike Steven Bell's 3m tape....my tape didnt last
the spoiler keeps popping off
need to get some glue and put it up once and for all
or I would steal some of Steven Bell's 3m tape
Search on YouTube for it to see demos of its strength.
http://www.shop3m.com/3m-vhb-heavy-d...trtqkpdt3.html
One thing to note: It's not cheap! Close to $40 a roll.
http://www.ebay.com/itm/Automotive-D...-/220839453034
I actually did not use the silicone that came with the spoiler. I did add another strip of 3M tape for added strength. Did the exact same thing with the one I put on the Maxiam and no problems at all for either vehicle.
Most important thing you should do when installing is wait for warm temps/weather. I did this in winter last year with 3M Trim tape and it still started to come off. I waited until spring to try again. It's been perfect since.
I installed mine with the temps right around freezing over a year ago and have had no problems. I may have been lucky, but just offering another perspective.
As Treblig said - clean the surface well before installing with isopropyl alcohol.
I did mine in the winter - but waited for a warmer day and heated up my garage with a torpedo heater for a couple of hours.
nanos
Nov 12, 2015 08:41 PM
oyayjoe
Sep 12, 2015 04:40 PM
