dash cam draining car battery
Old Jun 8, 2024 | 12:39 PM
peterc325's Avatar
hi - hardwired a Viofo A119 mini 2 dash cam to my 2010 acura mdx (tech version) with a viofo hk4 hardwire kit to the fuse box on the driver's side, and set the battery protection option to 12.4V.
dash cam was added by tapping into #9 (15A ACC Socket) and #13 (20A Passenger's power recline). dash cam works fine but my car wouldn't start after a week of being parked in driveway. had to jumpstart my car, i suspect it's because i had parking mode on and it was draining my car battery (changed between auto event detection and time lapse 3fps but still noticing battery drain).
now i turned parking mode off and unplug the dash cam when not using my car to prevent battery draining. any idea what could be the main culprit to it draining my car battery? i think i had the hardwire done right by watching many different installation instruction on youtube. aprpeciate any feedbacks.
Old Jun 9, 2024 | 03:13 PM
bryan916's Avatar
I had the same issue, it's because you tapped into a fuse that gets a constant 12V. If you have a meter, try finding a "switched B+" fuse. something that gets power when the ignition is on, no power when ignition is off. i think i tapped into my driver seat heater since its "switched B+". Haven't had a problem since.
Old Jun 9, 2024 | 03:29 PM
yeah but the whole point of tapping constant is for parking mode. It sounds like the Viofo’s voltage limit is not shutting off parking mode properly. My Blackvue will alert when voltage drops under the limit
Old Jun 9, 2024 | 09:17 PM
peterc325's Avatar
appreciate the response guys, hardwire kit was added to a constant and a off fuse box to allow parking mode function. circuit tester indicated #9 (15A ACC Socket) was off when car is off and on when car turned on and #13 (20A Passenger's power recline) was constant. don't think it's the fuse slot selection issue as that's what instruction videos on yt said.
yea agree somehow the hardwire kit wasn't doing the job it's supposed to do with battery protection option turned on. could the hardwire kit i bought is a defect? or the parking mode setting on camera could be causing the battery drain?
Old Jun 11, 2024 | 10:46 PM
bryan916's Avatar
I had the same issue with my Viofo hardwire kit, that's why i went with a switched B+ fuse. i guess i should've mentioned that lol
Old Jun 11, 2024 | 10:49 PM
bryan916's Avatar
My guess would be on the camera since my Viofo hardwire kit was doing the same thing. i also had it set at 12.4v, but i tried other voltages and it was still killing my battery.
Old Jun 12, 2024 | 09:36 AM
Reach out to Viofo support to see what they say... or return it and get a superior camera like the Blackvue
Old Jun 18, 2024 | 02:12 PM
echodigital's Avatar
From TL to RDX
Check out my setup with a Dongar Tech Adapter. The camera will only go on when I drive it (simple setup). Good choice on Viofo Mini 2. It is very discrete.
https://acurazine.com/forums/4g-tl-2...amera-1000569/
Old Jan 9, 2025 | 12:53 AM
Dreamliner's Avatar
Did you ever find a solution to this? I just bought a VIOFO A229, hardwire kit and fuse tap. Trying to figure out how to wire it properly. Thanks,
samantha.winslow
Mar 8, 2022 05:30 PM
tk2k6
Feb 19, 2016 06:19 AM
boomersooner02000
May 13, 2011 08:50 AM
KamikazeTL
Apr 5, 2006 11:13 PM
woodek
Feb 5, 2002 09:00 PM
