cracked turn signal assembly
hey everyone,
I was wondering if anyone knew how easy it was to replace the turn signal assembly that sits on the lower portion of the front bumper(same location people perform the switch back mod)
Has anyone had to replace theirs? Looks like mine was cracked by a rock.
Also, does anyone know the part #? I've been searching and can't seem to locate it; thanks
I feel like you didn't really look...
HEADLIGHT for 2014 Acura TL
33300-TK4-A11 or 33350-TK4-A11
Also note you don't make mention of your year (09-11 or 12-14) so we're going to assume 2014 for shits and giggles.
ok so i finally took some time over the weekend and replace the cracked light.
1 - access the work area by following the video below; you'll need a 10mm wrench(smaller the better) and a small flat head screw driver to remove those plastic plugs; i would recommend jacking up the car a bit so you have some room to work with
https://www.carcarekiosk.com/video/2...lights/foglamp
2 - if you reach straight up you can feel around for the 10mm screw that ties down the light to the bumper assembly; use a 10mm wrench and remove the bolt; you should be able to push the light out after that
3 - untwist to remove the wiring harness; assuming you have a brand new replacement, the replacement should already have the bulb assemby; reconnect the wiring harness
4 - insert light; tighten 10mm screw/bolt; and youre done!
uvb4less
04-15-2016 08:49 PM
sublim3style3
03-05-2016 06:16 PM
20033.2cltypes
2G CL Problems & Fixes
02-22-2016 03:44 PM
