Changing Reverse Lights
Just curious if anyone has changed the rear reverse lights to an LED Projector style bulb for better output. I had it before in my TSX but after looking up the service manual, it looks like the only way to remove the bulb is to completely remove the rear tail lights. What a friggen hassle!!
peel back the trunk linning, its 3 hex bolts, use little wrenches to take it off. The taillights should feel stuck, hit one of the bolts a couple of times to loosen it up and it should slide right out.
Keeping TL until 2029
I was thinking about using some LEDs for reverse but I read an AZ post about it blowing some fuses and causing some expensive repairs. Another one is using fancy stem caps that will break the TPMS module. Mod with caution.
i had my for 2 years without any problem of blow fuse. It could be the connector are touching next to each other to cause that problem. Fixing the connector on the LED bulb is an easy task. This is what I got on my
http://www.jlclightings.com/CREE-5W-...p/cr-39008.htm
Can one simply swap out these bulbs, or is a resistor or other equipment required? I know a resistor is needed for the switchback mod.
Also, is it simply a swap for licence plate leds? I recently got replacement leds for my puddle lights, my vanity's, my trunk, and the licence plate. Sadly (or "stupidly") I forgot I had to vanity mirrirs, and only ordered one set of bulbs. I've swapped those out, however I'm holding off on the others until it's warmer, and so that I can take some "before and afters".
Since you change the vaninity mirrors, how is the brightness?
I like it. I was worried that the leds would be too bright, but I think they work nicely. I got these in the "warm white" (as opposed to the "xenon white") and I think that helps. Brighter than stock, and good light spread, without being "too much". I'll see if I can upload some pics. Again, since I neglected to order for both sides, I've only swapped out the passenger side, and should be able to provide a comparison.
The reason why a fuse would blow is because there's a short.
The only reason why resistors are needed for the turn signals is because LEDs require a lower current which makes the car think a bulb is out, which makes the turn signals hyperblink (blink really fast to aware driver that a signal bulb is out).
The resistors correct this, and your TL will blink at the normal rate with LEDs.
Andrew, if you're looking for a BRIGHT bulb with good spread, go with the VLEDs:
http://www.vleds.com/shop-bulb-numbe...79-1-pair.html
They're on backorder right now, though.
Having a bulb with good spread is important so when you reverse at night, there are no hot spots seen from your reverse cam.
Same bulbs on my TL:
![](http://imageshack.com/a/img268/5315/gsqs.jpg)
![](http://imageshack.com/a/img690/7023/5w0e.jpg)
I think the "projector" style ones they sell at Nextmod would give you hotspots (they tested out a bulb for me when I was in).
The VLED bulbs emit light from the sides, making use of the reflector in the tail light, making the light spread better.
JLC Lighting Cree:
![](http://img141.imageshack.us/img141/7720/20111204200252.jpg)
VLEDS:
![](http://img14.imageshack.us/img14/3540/20111219204807.jpg)
awesome! all my lightbulbs have come from ijdm.
my wife been nagging me about changing those vanity light bulbs so she will have more light when she is doing her makeup but i refuse as i hate driving with interior lights.
I'm embarrassed to say, I didn't even consider that. The brighter bulbs may be more annoying to the driver when used while the car is in motion.
Also you think that the cree projector leds will be brighter but they were probably half as bright as the stock ones.... you need to buy a light that uses the reflector housing.
I just did this mod on the 4g and my Truck... I went with 42 LED SMD's no Projector and while I love the color they match the tag lights and the HID's, the output is no where near what the stock bulbs had... the TL isn't a big deal cause the tails are tinted and the windows are 5% reverse lights do nothing for backing it up... but the truck I need all the light I can get for backing up and loading trailers... So kinda pissed about the brightness... I'm going to pull them outta the truck... May look into the projectors...
Do you have a back up camera? I thought about changing my reverse lights also. But i've been in a car with very bright ones and they cannot see anything with the camera.. Maybe good for tinted cars without the camera but in all honesty.. I think the OEM rear view camera is paired perfectly. Very clear day AND night.
If I had any doubts, I would pull up or aim the headlights towards the spot before I backed in anyways.
rockyboy
12-06-2022 02:29 PM
mada51589
05-03-2022 08:54 PM
rockyboy
01-25-2016 06:00 PM
Soul_Deamon
4G TL Problems & Fixes
11-02-2015 04:32 PM
