Car and Driver Acura TL SH-AWD Manual First Drive
http://www.caranddriver.com/reviews/...t_drive_review
They test drove the car around the track agianst the BMW 335i and 335xi, Infiniti G35, and Audi S4 and they said
is that possible?
But—surprise, surprise—the TL is quicker around the track than any of the other cars.
I doubt it. From what the stats say, the Acura SH-AWD is low to mid 14 sec car. It might be able to beat the G35 and S4, but the bmw's will own it anyday. I'm sorry to say that. (335 series). Maybe they were referring to the 328 lineup.
Team Anthracite Webmaster
i kind of doubt that a magazine like Car and Driver would make such a huge mistake like that. If this article is true, it's certainly encouraging.
Nope, if you read page two, the TL SH was faster on the track.
for you doubters, here is another better more detailed article
http://vtec.net/forums/one-message?message_id=791083
definitely impressed me.
if Car&Driver tested the manual NOW, WHY we have to wait a year for the MT on the TL ShAwd??![Why Me](https://acurazine.com/forums/images/smilies/whyme.gif)
IF the BIG and FAT TL 4GN is faster of the lighter and smoller concurents of the test as C&D said is a very good thing...
BUT I'd preferred they compared the TL to the BMW535xi, or the M35x or
the Audi A6 3.2 quattro....
I'm pretty sure that the larger cars you mentioned would have been more than 2 seconds adrift. Man that would have been embarrassing!
![Lightbulb](https://acurazine.com/forums/images/icons/icon3.gif)
TOV
2010 Acura TL to Offer All-New Manual Transmission
Date: September 26, 2008 04:00
Submitted by: Jeff
Source: Acura PR
Credibility Rating: Not Specified
New 6-Speed Manual Will Be Available Next Fall on TL SH-AWD Model
TORRANCE, Calif. - 09/26/2008
By adding an available manual transmission to the TL SH-AWD® model, Acura will further up its game for performance minded TL drivers who prefer the winding route over the direct route, Acura announced today. Available next fall for the 2010 model year, will be a TL SH-AWD® with 6-speed manual transmission and numerous modifications to enhance vehicle dynamics.
"The new manual transmission equipped TL SH-AWD® really allows the enthusiast driver to take full advantage of the performance of Acura's SH-AWD® system," said Dick Colliver, executive vice president of sales, "Not only is the new manual transmission model the best performing Acura TL ever, it is the top handling performer among every vehicle in its class."
The availability of a 6-speed manual transmission for the 2010 TL SH-AWD® represents the first time Acura has ever paired its acclaimed Super Handling All-Wheel Drive™ system with a manual gearbox. In addition, the new close-ratio 6-speed manual transmission is approximately 110 lbs lighter than the Sequential SportShift automatic transmission to further benefit acceleration, braking and cornering.
The 6-speed manual transmission is an all-new design that is substantially stronger than the previous generation TL manual transmission. In addition to using a more rigid aluminum case and heavier-duty internals, the new manual transmission employs precisely selected gear ratios based on the characteristics of the TL's new 3.7L V-6 engine and SH-AWD® drivetrain. New gear synchronizers deliver improved shift accuracy and feel, and a short-throw shifter assembly generates confident shifting combined with low shift effort.
Acura engineers also designed an entirely new clutch system for the new 6-speed manual transmission to withstand the TL's robust power output while also improving modulation for noticeably easier use. The new self-adjusting, dual-mass clutch delivers extremely constant pedal effort throughout the entire stroke of the pedal. By keeping the effort linear, the driver has improved feel that results in better clutch interaction.
The TL SH-AWD® 6MT has a specially calibrated Hill Start Assist system that helps prevent the vehicle from rolling backwards when the driver switches from the brake to the accelerator while stopped on a hill. When the road incline exceeds an 8-degree threshold and the vehicle is fully stopped, Hill Start Assist automatically activates. When Hill Start Assist is active, the brakes automatically hold for one second as the driver's foot transitions from the brake to the accelerator pedal. The brakes are automatically released when the vehicle begins to move forward.
The 2010 TL SH-AWD® 6MT has exclusive suspension tuning via special coil spring and shock absorber rates tuned for flatter cornering with reduced pitching motions under acceleration and braking. The front dampers incorporate 5-percent more tension damping during low piston speeds to generate improved turn-in feel. In addition, the front dampers generate 14-percent less high speed compression damping which helps improve ride quality.
The TL SH-AWD® 6MT employs firmer engine and transmission bushings that better resist engine and/or transmission movement during spirited driving. Engine side mount bushing stiffness increases by 80-percent, front mount rate increases by 17-percent, rear hydro mount firmness increases by 50-percent and the transmission upper mount is stiffened by 100-percent.
For 6-speed manual transmission applications, special heavy-duty front driveshafts are used. In addition to being 2-percent larger in diameter, the driveshafts have a larger inboard spline size and team with more heavy-duty CV joints.
The TL SH-AWD® fit with the new 6-speed transmission will also benefit from exclusive Electronic Power Steering (EPS) tuning. Just as with the TL SH-AWD® with Sequential SportShift 5-speed automatic, the EPS delivers low steering effort for parking maneuvers that progressively firms up as speed increases.
With the 6-speed manual transmission TL SH-AWD®, the EPS system is further tuned to deliver a slightly heavier feel as speed increases thus generating more confident mid- to high-speed driving dynamics.
The addition of a manual transmission, an all-new clutch system and suspension changes yield an 88 lb. reduction in overall vehicle weight. The weight reduction not only delivers improved performance, but also generates a more favorable front/rear weight bias. Compared to an automatic transmission equipped TL SH-AWD®, the 6-speed manual version improves weight distribution by 1-percent thus generating a 58/42 ratio versus the 5AT's 59/41 ratio.
Acura offers a full line of technologically advanced performance luxury vehicles through a network of 270 dealers within the United States. The 2009 Acura lineup features five distinctive models including the RL luxury performance sedan, the TL performance luxury sedan, the TSX sports sedan, the turbocharged RDX crossover SUV and the award-winning MDX luxury sport utility vehicle.
Submitted by: Jeff
Source: Acura PR
Why does any manufacturer stagger the introduction of various models or trim levels? It's not like Porsche didn't bring out the big engined Cayman first to be followed by an affordable version later, or BMW didn't introduce the new 3 with a carry over engine first, followed by a stronger version, followed by a turbo version, followed by a M version.....
But in my opinion with the 4GN the TL is not more a concurrent of the 3, A4, IS, G35 series...
About the trims levels...
think at the confusions of the engines ranges in BMW, Audi, Merc: a 1.8T, 1.9 TDI, 2.0TFSI, 2.0FSI, 2.0TDI... get creazy.
One of the most RIDICULOUS case is for the Bmw sedan M3.
It was presented one year ago, and buz!! after a few months they got the 3 serie restyled and the M3 sedan too was restyled... I can imagine the happiness of the owners..
The Audies get the R the lest 2-3 years of their cycle: the RS4, RS6, and now you can buy a new RS4 cabrio of the OLD model or the S4 of the new one!!
Nice find. The article is certianly encouraging. I'm still waiting for the Type-S version to come out before I start shopping though.
Ak Ting Up
Also....
The SH-AWD tested is speed limited to 130mph. It may be fast on the track, but on the interstate it will get killed by everthing from the Mazda 6 to some newer Civics. Not to mention EVERY 3g TL made.
On a positive note, I'm glad to see a Honda beat a BMW around the track
On a positive note, I'm glad to see a Honda beat a BMW around the track![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
Yes its technology the ECU has a speed limiter it is the dumbest thing on the planet. I don't want to be told when i can stop punching my gas
As far as the new TL being limited to 130mph and being owned on the highway by vehicles that aren't electronically (or otherwise) limited to such a "low" speed goes - where and how often are you going to reach those speeds here in the US? The new TL is very quick and smooth on the highway and runs from 60-100 are quick, effortless and drama-free (I speak from first-hand experience).
Obviously, they are quick on the track as evidenced by the article above and I believe that more than 99.9% of the drivers out there will never be hampered by the 130 mph limitation - and if you are in that HUGE minority who would be, I'm sure you can find ways around that! :wink:
Just use some common sense and keep it on the track and don't kill yourself or someone else, please.
Why in hell whould you want to go faster on a road that everyone uses. No wonder people die in car's.
Yes, indeed - the SH-AWD is the new "higher performance" designation for Acura
Just use some common sense and keep it on the track and don't kill yourself or someone else, please.![2 Cents](https://acurazine.com/forums/images/smilies/2cents.gif)
115-142mph daily (by daily i mean if im in the mood) - There's a closed down road that cuts between two places its part of a wildlife thing here. No cops go there no one even checks it...its heaven
When I have a faster car I plan on breaking into the 150-160s.
But I don't like the idea of being hampered.
that's great that you have a non-public road that you can enjoy your car on - but if you're racing other cars (worried about getting outrun by a Mazda, etc) I can't condone it - and watch out for the wildlife in that area - hit a chipmunk at 130 or better and I don't have to tell you what could happen. But if you insist, there are ways to get around that limitation like I said before.
The lexus got destroyed and the porsche was just having fun hugging my bumper around turns :P
But yeah i'm always safe...if i wreck its me and maybe a tree that goes down no one else. I don't do too much crazy stuff on public roads...I mean i've hit 130mph on the highway but i made sure i was safe to do so.
Ak Ting Up
And what I am saying is that a NEWly Designed TL, with Super Handling, and 306hp, should be faster or as fast as a previous model of the same car, 5 years older.
If you didn't know, the 3g TL, non S type, Auto trans, will hit 150mph.
So, your on I-75 South, its a long stretch of three lanes, low traffic, and you are in your 2010 TL, SH-AWD, your rolling about 78-80 (posted speed is 70mph). Your feeling good watching your doppler radar. You look over to the left and see my 04/TL gaining on you. You decide to match speed, all the way up to 130mph, where your car shuts down (bucks) and I continue on, leaving you.
After I show you that you cant keep up, I slow down to your speed.
I also pass you when you exit the highway to get gas, seeing that my 04/TL get better gas mileage than your 2010 TL SH-AWD.
don't think I'm without sin here, too...I've driven fast enough (130+) on public roads before but it was late at night on an empty interstate - and I was younger and didn't have a family of my own to consider. Now I'm a little older and have responsibilities AND I realize how "not smart" it was to risk o much for the short lived thrill that came from such high speed runs.
BTW [/ threadjack] - sorry
it's me, Alan Rickman.
what the hell happens when you hit a pothole at 130mph or have a tire fail?
anywho..
![](http://a332.g.akamai.net/f/332/936/12h/www.edmunds.com//media/roadtests/firstdrive/2010/acura.tl.sh.awd/2010.acura.tl.6MT.det.shifter.500.jpg)
Looks nice!
IMPORTANT QUESTION THOUGH! Will you be able to get the keyless access system with the 6MT SH-AWD TL?!!?
anywho..
Looks nice!
Ak Ting Up
[QUOTE=fleshy;10030762]what the hell happens when you hit a pothole at 130mph or have a tire fail?
I'm sure it will be bad, but it hasn't happened yet. I did have a blowout in a 530I at 80. No drama, six lanes of Interstate to get her under control and get to the shoulder.
Ak Ting Up
I'll Concede
Expert road engineers determine the maximum safe speeds for any road.
Anyone driving faster than the posted speed is driving unsafe according to the NHTSA.
The new TL is ugly.
The new TL is ugly.
"...it looks like the giant shovel that hit the front end was left where the grille should be...." (Car & Driver) <--- ROFLOL - I could not resist.
Its great that the MT will improve quickness by about '0.7 s' vs. the auto. However, a SH-AWD TL quicker around a twisty track that a 335i, G35 and S4? This can't be a surprise. The twisty track plays to the strengths of SH-AWD.
Now, how about a 335i vs. 4G TL MT heads-up on a straight track?
34 years on the fire department and I'm throwing the BS flag on this one. I'll save the lecture, but it's this attitude that kills innocent people, and that's firsthand experience talking-not just an opinion.
"1st Place: While the 2010 Acura TL SH-AWD 6MT might not have the horsepower to keep up on the straight with any of these other sport sedans, it works best by far in the corners and made up time over its competition in speed at the apex and at the exit."
http://www.edmunds.com/insideline/do...hotopanel..1.*
AZ Community Team
I do not know how anyone can say they are safe doing 130MPH and "don't do too much crazy stuff" on a public road?
The TL destroyed s4, g35 and 335i. At this point, everyone can easily guess what would happen to bigger brothers of the above when put against the new TL. On that note I see no reasons to see such comparison.
Also i never do those speeds if anyone is in sight front/back/side. When i get the open road...public/not and the itch to vtec...i let the car have its fun with me.
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
6G TLX-S
The new SH-AWD TL has torque vectoring (L/R torque splitting for rear wheels) which significantly increases cornering performance. In fact, it is so superior that Audi is scrambling to catch up the technology ever since the SH-AWD RL has come out.
Audi is working on similar torque vectoring addition to it's Quattro system, and this upgrade probably still hasn't applied to the Audi test car yet.
6G TLX-S
I don't think it makes sense to compare the TL with the 5-series, M_5, and A6, because they are not in the same price class. The RL is.
The TL is in the same price class as 3-series, G_5, A4, and even C-class, which is exactly what C&D is doing comparison tests with.
