CAn an RDX steering wheel fit a TL
Old Apr 10, 2024 | 06:21 PM
mrphilipanderson's Avatar
The mesure Identical. They look identical. The harnesses look the same. Has anyone ever tried it?
I've included the fronts and backs of Each. Please share your thoughts.
RDX/iLX STEERING WHEEL
TL/ZDX STEERING WHEEL
TL/MDX STEERING WHEEL
Old Apr 10, 2024 | 08:51 PM
altair47's Avatar
Why do you need a steering wheel from RDX? He's terribly thin.
Old Apr 10, 2024 | 11:24 PM
Because my steering wheel is messed up...peeling etc.
And I ound one for DIRT CHEAP and its BRRAND new unused. I would accept thin instead of peeling.
Old Apr 11, 2024 | 02:59 AM
john-germany's Avatar
It should work but you can also swap the electronic to the other steering wheel.
Old Apr 11, 2024 | 06:24 AM
altair47's Avatar
Do you think it’s true that he’s a brand new? Or did someone wash it well? I have 2 of these steering wheels at work. I'll see the difference.
Old Apr 11, 2024 | 08:45 AM
altair47's Avatar
He's completely different
Old Apr 11, 2024 | 07:59 PM
Darn. Thank you so much for taking the time. They are completely different when you look at their mechanics. I was hoping I would be lucky enough to make it work. I miss having a pretty steering wheel.
Old Apr 11, 2024 | 08:42 PM
altair47's Avatar
These are decent steering wheel, 3 minutes with Windex and they will be like new. https://www.ebay.com/itm/235465883173
Old Apr 13, 2024 | 02:24 PM
Ascension's Avatar
I can confirm that the 4G TL and ZDX steering wheels are interchangeable. I purchased a TL SH-AWD steering wheel, which is the "sport" version that the TL SH-AWD and ZDX Advance received, that I swapped into my ZDX Tech. I value the extra girth of the sport variant, and believe it's a drastic difference compared to the base model.
https://acurazine.com/forums/zdx-326.../#post16904845
Old Apr 14, 2024 | 02:17 AM
most of the ones youll find on ebay are for the 3.5...the skinny version. The 3.7 is thicker.
Old Apr 14, 2024 | 04:04 PM
csmeance's Avatar
New steering wheel is around $250, you'd have to swap over the switches and other items. My Cruise Control switch broke and it was fairly easy to swap it all out in the driveway. Make sure you undo battery to avoid SRS issues.
Old Apr 14, 2024 | 09:29 PM
I’ve done things like breaks and all the fluid changes. But changing steering wheel scares me. Is there guides to show how to put in back on in the same angle u pulled it off ? Is a steering wheel alignment necessary
Old Apr 14, 2024 | 10:09 PM
altair47's Avatar
It’s simple, there is a 12 o’clock mark.
Old Apr 16, 2024 | 06:46 PM
csmeance's Avatar
I took the bolt off and make a large mark with a wax marker to ensure I lined it back up properly.
Its honestly not that big of an issue. Just make sure the wheels are straight and the acura logo is pointing straight up before and after removal.
DAC17
3G RDX DIY & FAQ
36
Jan 31, 2024 03:59 PM
DaIll1
Apr 29, 2022 07:36 PM
Arod123
3G RDX (2019+)
Feb 22, 2022 03:51 PM
Dave2094
3G RDX (2019+)
May 27, 2021 03:49 PM
Dave2094
3G RDX (2019+)
Jan 6, 2021 10:24 PM
