A/C auto off
Old Oct 13, 2009 | 10:45 AM
rvalentino's Avatar
A/C auto off
Is there a way to set the A/C to automatically be off when the car starts? Most of the time I don't want the A/C running and noticed I have to shut it off. That is a problem because the A/C is starting up momentarily when the air is first turned on. I don't want the added strain on the A/C motor due to coming on every time.
Old Oct 13, 2009 | 11:02 AM
venom550pm's Avatar
My beer fridge is in
good question, check the manual.
Old Oct 13, 2009 | 02:14 PM
Eli's Avatar
Eli
Yeah if you hit the A/C button it overrides the automatic control. If you push it once, it says "A/C off" on the display, and it won't ever go on automatically.
I heard that it's good to let the A/C run at least periodically as opposed to letting it sit unused for long periods of time.
Old Oct 13, 2009 | 03:31 PM
Kingmeow's Avatar
Eli is correct. I leave my off ever since I picked it up a few weeks ago from the dealer (it's starting to get cold here in the Northeast). Yes, you do want to run it from time to time as the refridgerant has a lubricant in it and that's what keeps all the rubber bushings, gasket, what have you, from cracking or drying up. This is true for any car.
Old Oct 13, 2009 | 03:49 PM
bagbklyn's Avatar
I really don't think people have to worry about running the A/C to lube it up, unless you live in a dry state where you are most likely using the A/C anyway. If you are using the front defroster which would be in a non dry state, if it is raining or really humid the A/C turns on when you push the defroster button. So it is very unlikely that someone will go through 2-3 months without using the A/C unless they're hypermiling and in that case it's a different story. One thing it does say in the manual is To keep stale air and mustiness from collecting, you should have the fan running at all times.
Old Oct 13, 2009 | 07:30 PM
wmahmud's Avatar
Just a random question kind of related - when driving or more when idling at a light, do you hear and feel (very slightly) the compressor coming on and off, when using Auto Climate control? or is that something else I am hearing come on and off every little while? fan? blower? something?
Any thoughts or help?
Old Oct 13, 2009 | 09:07 PM
Eli's Avatar
Eli
Yeah it's probably the compressor cycling.
Old Oct 13, 2009 | 10:05 PM
wmahmud's Avatar
But is that normal? Im coming from 05 Cavalier (so yes day and night) but like I never even used to feel it come on and off in that unless I was idling in a hot summer day and the temp would get up ..then the fan would come on to cool the engine down
Sorry for the noob question
Old Oct 13, 2009 | 10:29 PM
Colin's Avatar
I think you're feeling the compressor clutch engage. Yes, I believe it is normal since I can feel it in many Acuras. Could it be more 'refined' ..... YES! But I don't think you have anything to worry about.
Old Oct 13, 2009 | 10:38 PM
wmahmud's Avatar
Thank you!!
Just want to be sure my car is like others!!
Old Oct 15, 2009 | 11:03 AM
rvalentino's Avatar
So I guess there is no way to default to "AC off," right? I turned the car off with AC off. The next time I turned it back on it was back to auto (nothing displayed for AC). I assume at this setting the AC will come on if it detects high humidity levels in the car, but there is not really a way to know if its on at any given time. I don't hear the compressor at all.
Here's what the manual says:
"Air Conditioning (A/C) Button
This button turns the air conditioning on and off. You will see A/C ON or A/C OFF in the display (in the center display on models with navigation system).
When you turn the A/C off, the system cannot regulate the inside temperature if you set the temperature control below the outside temperature."
It doesn't tell me anything I didn't already know.
Old Oct 15, 2009 | 12:29 PM
Kingmeow's Avatar
That's not true. On my 09 AWD Base, it's off and it stays off.
1. Start car.
2. Turn A/C off but you can leave your fan speed to whatever.
3. Shut car off.
Next time you start the car your A/C should be off. Do not touch Sync or the climate control system.
Old Oct 15, 2009 | 02:05 PM
Khash's Avatar
I think it's normal. It does so less frequently when the temperature inside the car equilibrates to what's set by the driver/passenger.
Old Oct 15, 2009 | 02:26 PM
4G Express's Avatar
I was going to make a thread on this as I dont understand why the AC goes on when I put the heat on. I drove around and I noticed less gas mileage and sure enogh I had to hit AC off even though the temp was on high. Im sure there is a reason, I just have to be aware and remember to turn it off.
Old Oct 15, 2009 | 02:34 PM
Haelous's Avatar
Compressors also act as dehumidifiers. So, just because the air is warm doesn't mean you wouldn't want it to be less humid as well.
Old Oct 15, 2009 | 03:26 PM
Eli's Avatar
Eli
1. Start car.
3. Shut car off.
Also if you have the tech package the settings are linked to the smart key. So if you started the car with the other key, it may explain why the settings were different than before.
Old Nov 3, 2009 | 01:54 PM
rvalentino's Avatar
1. Start car.
3. Shut car off.
This works if you leave the fan on when you turn the engine off. I always turn the fan and other electronics off before turning the engine off.
Old Nov 3, 2009 | 05:12 PM
Kingmeow's Avatar
Hmmm...interesting. Come to think of it I do leave the fan where it was last set to but never off. That's probably why it works for me!
Old Nov 3, 2009 | 11:54 PM
wmahmud's Avatar
Doesnt the slight jerk of the compressor going on and off bug people? I notice it more when stopped at traffic lights..the slight jerk is what bugs me..
Old Nov 4, 2009 | 05:18 AM
dwest1023's Avatar
It bothered me at first but I am sought of use to it now. It almost feels like someone has bumped you in the back.
Old Nov 5, 2009 | 05:50 PM
wmahmud's Avatar
Exactly - find it so annoying, don't get how they couldn't avoid that in such a nice car.
Old Nov 6, 2009 | 11:26 AM
febdragon's Avatar
Me too... it really bothers me.. but what can you do? My other car is Lexus RX330, and the compressor on/off is noticable, but the car doesn't jerk like the TL. Does all Acura have this "feature"?
Old Nov 6, 2009 | 01:57 PM
Eli's Avatar
Eli
You'd think cars would use electric a/c compressors instead of leeching off the engine constantly, then they could run them at variable speeds depending on demand. They already have electric power steering, seems like an obvious thing to do.
Old Nov 10, 2009 | 08:48 AM
Hondasforme's Avatar
Most if not all Automatic climate control systems always run the A/C even with the heater on. This gives the system pinpoint accuracy in regulating the climate by reducing the humidity levels and having perfect cold and hot temperatures to mix in order to achieve the desired temperature.
Old Nov 10, 2009 | 01:41 PM
Colin's Avatar
Not surprisingly, here in Honolulu I run A/C all the time. By setting the temp control to "LO" and the fan speed to manual, I do not get the compressor cycling on and off.
Biggie_B
May 27, 2025 05:51 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
hashbrown
Sep 29, 2015 12:13 PM
malvothegreat
Sep 29, 2015 12:38 AM
jmaxima03
Sep 27, 2015 10:22 AM
