Appropriate Coolant Level?
Old Dec 20, 2009 | 01:46 PM
Chick-Chick's Avatar
4th Gear
Hey there.
I have a 2 month old TL (with navigation system) and noticed that the coolant level within the reserve tank (overflow reservoir) is a hair higher than the MIN mark when the engine is cold. The dealer says that this coolant level is OK. However, the owner's manual states the following:
p.550: "If the coolant level in the reserve tank is at or below the MIN line, add coolant to bring it up to the MAX line."
While the next page in the manual states the following:
p.551: "6. Pour coolant into the reserve tank. Fill it to halfway between the MAX and MIN marks."
What is the correct coolant level within the reserve tank when the engine is cold; halfway between MIN and MAX or at the MAX line?
Thank you for your clarification.
Chick-Chick
Old Dec 21, 2009 | 03:04 AM
ll_22's Avatar
Same w/ mine, then I noticed the reservoir cap was loose. not sure if the cause but fluid level stable since. The reservoir is an overflow collector so the dealer is correct, but I'm concerned that more water evaporated and hence heat protection in the summer is down. I might add some distilled water in the summer....
Old Dec 21, 2009 | 09:05 AM
Xpditor's Avatar
The marks mean what they say. As long as the level is between MIN and MAX, you are fine. Usually, when cold, the level will be closer to the MIN. When hot, because of expansion, the level will be closer to MAX. You can't put too much in because it will just overflow onto the ground. It won't hurt the car.
I usually top mine off when cool right up to the MAX line but it will self adjust when it gets hot and the excess flows out.
Does that help?
Old Dec 21, 2009 | 10:46 AM
Kingmeow's Avatar
Do you have to use "Acura Coolant" from the dealer? If not, which brand(s)?
Old Dec 21, 2009 | 11:52 AM
akash4u's Avatar
I dont know what brand/type coolant is in it currently. But my level is less than MIN and I want to top-off the reservoir to something between Max and Min. Can I use any coolant ?
Old Dec 21, 2009 | 12:45 PM
dwest1023's Avatar
No,use the honda coolant or equivalent. Anything else can void warranty.
Old Dec 21, 2009 | 12:50 PM
dwest1023's Avatar
Originally Posted by Chick-Chick
Hey there.
Chick-Chick
If the coolant is overfill, it is ok. The fluid will spill out the reservoir itself if the pressure becomes to high.
Old Dec 21, 2009 | 02:55 PM
Xpditor's Avatar
In reality, a good quality, name brand, all engine coolant would work. However, in an abundance of caution, not to give the dealer a reason to question proper maintenance, and, since we do it so seldom, I prefer to spend a couple extra bucks and get the Honda/Acura coolant. It is premixed at 50/50 so you don't dilute it.
The owner's manual says it is OK to use something else temporarily until you can flush it and replace with Honda/Acura.
I have my own doubts it makes a big difference. But with a $40k car, why mess around?
Old Dec 21, 2009 | 03:03 PM
Xpditor's Avatar
There is no pressure in the reservoir. Liquid only flows to the reservoir if pressure builds in the radiator. That will happen normally with a hot engine, in which case the excess coolant flows into the reservoir. During such times, the reservoir level will rise.
Then, when the radiator cools down and pressure drops, the reverse happens. A vacuum is created and coolant is siphoned from the reservoir back into the radiator and the level in the reservoir drops. Think of the reservoir as a cushion or buffer. Without it, the expanded liquid overflow from the radiator would run on the ground.
Coolant reservoirs are relatively new to automobiles. They came around about 20 years ago or so.
Old Dec 21, 2009 | 03:24 PM
Kingmeow's Avatar
Well, I just checked mine and it's at the Min level and the car has sat in the garage for 24 hour. I'm just going to ask them to add a smidgeon more the next time I bring it in for service. No sense spending $$$, buying a gallon of the stuff, and use 6 oz.
Old Dec 21, 2009 | 05:27 PM
dwest1023's Avatar
Well aware, I just worded it wrong. The coolant will still run on the ground if the reservoir fillls all the way up until the correct level is obtained. That is why I say in makes not difference if the reservoir is above the full mark.
Old Dec 21, 2009 | 06:30 PM
Xpditor's Avatar
(I know that's what you meant to say. )
Old Dec 21, 2009 | 07:12 PM
4th Gear
Thank you all for the information!
Chick-Chick
Old Dec 22, 2009 | 12:56 AM
BLACKURA_NY's Avatar
I have car ADD
one thing i never mess around with.... is fluids...
On every Acura/Honda ive owned.... Always use Honda ATF-Z1 and Coolant
They spend millions of dollars engineering these cars, and these fluids.... saving $5-$10 isnt worth compromising the outstanding reliability of my Acuras
Here is some food for through on Honda/Acura coolant
http://www.acura-legend.com/vbulleti...ifreeze-21171/
Old Dec 24, 2009 | 06:54 PM
jjar03's Avatar
Coolant is cheap. Honda or Acura branded coolant is the same except for the price. So, do buy some Honda branded coolant in the Honda stealership for example, I think that it does not come in containers of less then 1 gallon but again, it is cheap enough.
For sure, when the engine is cold, top off the expansion dish to the max mark. It makes perfect sense, since the max mark is below the top of the expansion dish which provides space for expansion that will happen when the engine is cold.
Old Jul 13, 2014 | 04:26 PM
Bobby39's Avatar
Was just checking my coolant level and it is way less than minimum. The car sat in the driveway for 18 hours, should I add more or is that normal?
Old Jul 13, 2014 | 11:54 PM
Edward'TLS's Avatar
6G TLX-S
Add more coolant up to the MIN marking, when the engine is cold.
LeVeL
Oct 18, 2015 04:19 PM
Houston
Oct 8, 2015 01:27 AM
ROSSARONIE
Oct 2, 2015 11:46 AM
steve
Sep 30, 2015 09:23 PM
Username 0
2G TSX Performance Parts & Modifications
23
Sep 28, 2015 09:09 AM
