Anyone know where I can get a power source for fogs in the fuse box?
well im trying to see if i can wire my fogs independently without the use of the stock wiring system.
where in the fuse box can i get a 12v pwoer source to power up my fogs. i will be running a relay kit.
sorry but im a bit noob when it comes to electrical.. can anyone point me to a diy guide? or something similar. i want to be able to turn on my fogs independently with a switch
6G TLX-S
The OP isn't adding a new set of fog lights.
He wants to control the existing OEM fog lights independently with a standalone switch, without interacting with the factory fog-light wiring system.
My apologies, I thought I added it. Heres the link: https://acurazine.com/forums/3g-tl-2004-2008-93/g-029-07-08-acura-tl-diy-fog-light-mod-845798/
I have a diagram somewhere in the 4g section. You CANNOT wire the fogs the same way you do the 3g. The fogs are controlled by ECM and you will damage it if you do not know what you are doing. The factory Manual shows no safe way of doing independent fogs. What I did was to buy new fog connectors and rewire the fogs from scratch. I used a honda Foglight switch which perfectly match the TL dash. However it might be more of a challenge for you to wire this switch as it involves splicing into the dash illumination wire. You can use any single pole switch if you don't care about a factory look.
6G TLX-S
According to the above linked thread "G-029: '07-'08 Acura TL DIY Fog light Mod", it shows that the 3G fog lights are also controlled by the MCU/PCM.
So what the OP did on his 3G TL will also work for the 4G TL.
Basically, the OP completely separated both the fog light relay and the existing fog light switch from the factory wiring system, and then rewired them up together independently.
However, this involved lots of wire cutting and splicing, and should not be carried out by an inexperience person.
not sure what you mean by illumination wire...
isnt there a fuse for "ACCESSORY" so when the car turns on, the fogs will turn on with it to as well as turn off at the same time.
What's your end goal? What are you wanting to modify / change?
If you're wanting to NOT power the fogs by the standard connection, you won't damage the electrical system by not using the factory connector.
Running a hot lead from the battery, just like you would for a stereo amplifier, and then putting a fuse between them and the battery, and an interrupt switch on the ground (to toggle them on and off from the cabin) is pretty easy wiring.
Pick if you're going to run a switch on the hot lead or the ground.
If you're going to do the hot lead, run a line to an inline fuse between the battery and a 2 position switch. Run the line out of the switch to the positive feed on each light. Run a ground line from one of the ground straps / anywhere you can bolt to the frame of the car into the negative leads on the lights.
When you flip the switch, you connect power to the light. When it's off, the switch still has voltage, but the lights do not. This also bypasses all the cars "idiot" features and you can leave the lights on when the car is off - so you CAN drain your battery by leaving them on.
You can do the same thing by switching the ground instead. You'd run a positive wire with an inline fuse from the battery to each of the lights positive leads, and then connect the grounds of the lights to each other, running a wire to the switch and then a wire from the switch to a grounding point. You get the same thing, but you don't have voltage going through the switch, just the ground. Same thing though, you end up bypassing all the car safety features. You're just hooking up lights to a battery.
This is all mega simple electrical stuff - so if you're not comfortable digesting it as such, I'd let someone else tackle the project you're thinking of, or leaving it alone.
Pseudomaniac,
i know how to just wire - and + to the battery, but i want it to where it will work with the car.. like the fuse box.
i have done this with my integra back in the days where i had both - leads from fogs grounded to chassis and 12v power source came from fuse box. I did it this way so that when i turn off the car, the fogs turn off as well, but i can run independent fogs.
Will this work the same way?
If all you want to do is have your fogs come on when you start the car, all you will need to do is cut the the wires to the fogs. Wire one side to ground, and take the the other wire and connect to hot on daylight running lamps. Use a inline fuse between the hot line and fogs.
what do you mean by "HOT"?
do you mean positive (+)?
also, here is a diagram i would like to follow. i am going to purchase another set of fog light plugs so i do not have to splice my factory one just like you. I will not be using the car's factory fog light harness rather to use a seperate switch
my question is, do you think there is a socket in the fuse panel where i can get a power source to power up the fogs as you refer to "HOT" line.
[QUOTE=potmilkz;14109290]what do you mean by "HOT"?
my question is, do you think there is a socket in the fuse panel where i can get a power source to power up the fogs as you refer to "HOT" line.[/QUOT
The reason I used the parking light + was, if I left the fogs on, they would cut off automatically. Im not sure this will happen using a Accessory +. They make a fuse tap and you can just tap on any accessory or hot fuse.
well im not worried about having automatically cut off as i do not even use that feature on my car.
im just more concerned about having it shut off when the car is off..
now do you think it is safe to use the fuse box accessory to power up the fogs as a HOT wire? also i am going to be using a fuse tap.
i dont think its the same..
again dwest is advising to wire it independently and not use the stock harness.
i will attempt this soon. i know what needs to be wired now.
ill do a diy for you guys
G-luck with this mod P-milkz.
6G TLX-S
No, I mean what peeps did on the 3G by just modifying the existing wiring and using the existing fog light switch on the combination stalk. According to Edward'TLS, per my quote of his above, the 3G wiring mod, documented in this thread, should work on the 4G as well.
So this should work on all cars, like Dwest1023 has said.
However, this involved cutting up lots of wires in the factory lighting system.
What the 3G guy did was completely separated (=cut off) both "the fog light relay" and the existing "fog light switch" away from the factory wiring system, and then rewired the two up together into a new circuit. So the new circuit became a separate circuit and had no connection to the factory wiring system at all, other than the pair of fog lights.
I believe there are laws that govern how auxiliary lights should work. I know fogs are suppose to cut out when the high-beams are on- at least in California. Hopefully the 4G fogs are better than the 3G fogs- I don't use mine at all. I went with a DRL LED solution instead and that is always on with the ignition.
oyayjoe
09-12-2015 04:40 PM
