9005 JDM High Power 7600lm COB LED 60W Daytime Running Light
Hey guys I am just looking for any inputs on the new 9005 JDM High Power 7600lm COB LED 60W 6000K HeadLight Daytime Running Light for the replacement of the stock 9005 bulb in 2012 TL. I already have Osram 5500K CBI as low beam. Just trying to much in color. Is anyone using the new led in their acuras as 9005 bulb? It looks ok but I don't belive the 7600lm, I can bet it is a lot les lm?
here is the link to feabay
http://www.ebay.ca/itm/9005-JDM-High...-/131280733835
I've been running these http://www.ebay.com/itm/271269794208?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AITFor the past year with no issues. Pure white as DRL's and bright enough to flash or as hi beams. Even as DRL's they are bright enough to light up my garage at night.
JTL12 (11-05-2014)
I've been running these 2X 9005 HB3 COB LED Bulb Hi Low Headlight Fog Daytime Running Light White 40W | eBay
I do, its not near as far reaching as the halogens but still useful. With the factory HID I dont use them much anyway but they are there, great to flash people who are hi-beaming me....
The Original Shawdy
Where's the link Brock?
topless forever (09-06-2014)
Completely plug and play comes with everything you need. Error eliminator boxes and all. In fact on the first car I had them on they were on full power and they were too bright for DRL's I thought. So at DRL voltage they are just right and you don't lose the ability to flash them.
J just purchased a set of the 9005 JDM High Power 7600lm COB LED 60W Daytime Running Light. When I get them I will post pictures before and after. I think I will be done for a while with leds. Low beam upgrated to CBI 5500K, vleds white amber swtchback v3 triton, and morimoto xb led fog. I think I will have enough white light in front of my car.
You are a brave soul buying expensive electronics like that from Hong Kong,last time and only time I got something from outside the US it took a month to get here. If it fucks up on you, you have to ship it back on your nickel wait for them to get it,then ship you a replacement. That can be a couple months just to get your gear. That was one of the main reasons I got the ones I did, they ship from San Francisco.
Contact Potzmilk and see if he will post the video again or try looking for it on Youtube. The kit works perfectly and are much brighter than the HIDs.
Here is what I bought off ebay.
Here what what it look like on sunny day against bright background at half power. Not 7600lm but certainly bright enough for DRL. Lights up well at night too on high beam.
JTL12 (09-17-2014)
Here is my update on the 9005 JDM High Power 7600lm COB LED 60W 6000K. Install was very easy. The light output was not what I expected plus the cooling fans were very very noisy ones when the high beam was on. I just simply returned them got my full money back and got the same ones as DevilDogDoc suggested. 40Watts each High Power COB LED 9005 (HB3). They are simply plug and play. They are nice and very bright. No interfere with FM radio, navigation what so ever. DRL and High beams in full function with no errors of any kind.
http://www.ebay.com/itm/2014-New-40W-4800-Lm-Cree-LED-Headlight-Kit-Bulb-9005-9006-H8-H11-H4-H7-/131224044422?pt=Motors_Car_Truck_Parts_Accessories&hash=item1e8d900386&vxp=mtr
I don't remember if this is exactly the same store but the pic looks the same. If you do a search on Ebay for 9005 cree LED you'll get alot of choices. As with anything on Ebay, choose your poison wisely
In San Bruno. I would send him a message and see if he will list one for you.
Kumar-TL (11-04-2014)
You need a piece for the lights to fix the radio issue, I forget the exact name but radio shack sells them. They are cheap and it blocks the signal or changes the frequency so the ballasts and radio aren't on the same one. I had to do this on my Cobra.
Just orderded these from eBay. Let see how they go I will keep everyone updated. Sadly the seller that Devil Dog used has none of these lights in stock so he directed me to this seller.
New High Power 60W COB LED 7600LM Headlight Driving Fog Light DRL 9005 9145 Bulb | eBay
http://s3.showmecables.com/images/ca...rrite-bead.jpg
I'll try them and report back.
Also, I had some flickering on my passenger side DRL LED. The flickering only happens when the lights are used as DRL - there is no flicker when they are used as high beams.
My suspicion is that the flicker is caused by low voltage. The harness only supplies around 6Volts for DRL. I ordered a set of capacitors from VLEDS that are supposed to fix this:
http://www.vleds.com/in-line-cap.html
mada51589
05-03-2022 08:54 PM
rockyboy
01-25-2016 06:00 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
