6 Speed Manual Transmission
Old Oct 26, 2019 | 05:05 PM
jackaa's Avatar
Hi,
I have a 2006 TL with a 6 speed manual transmission that had the 3rd gear issue that I fixed by going to the GM synchromesh fluid. Also,it smooth out the shifting , or made shift changes smoother - less notchy.
I have a 2013 TL SH-AWD (3.7) with a 6 speed manual transmission and I want to change the transmission gear oil.
I could not find the fluid capacity (2+ quarts?), and searching on line does not show how to change it. There are many Honda/Acura MLT changes, but the drain and overfill openings are not what appears to be on the 2013 6 speed SH-AWD.
The drain bolt/plug appears to be on the bottom listed as MLT, but I could not find a weep overfill bolt opening. Is there a weep overflow bolt/plug?
Also, has anyone used the GM synchromesh FM in a 4th Gen 6 speed manual, and wha did you notice after the change?
Jack
Old Oct 26, 2019 | 08:25 PM
Riboflavin's Avatar
I switched to ACDelco 4014 synchromesh and saw a night and day difference. I used standard Honda MTF for years (bought my 4G 6MT in 2014), and noticed 1st to 2nd shifts were randomly squishy or crunchy feeling and 2nd to 3rd shifts could be so squishy that it'd pop out of gear if I didn't push it in with decent force every time I shifted (similar to the 3Gs popping out of gear). Yet sometimes it shifted fine, so very intermittent. After switching to synchromesh in Aug 2018, all of those problems went away, and every shift feels significantly better.
Capacity is 2.2 qt for fluid change (2.6 at overhaul), there is a check bolt on the side that you can fill it from, but I always just fill it from the top using a long funnel.
Old Oct 26, 2019 | 10:25 PM
jackaa's Avatar
So the drain plug labeled MTF is the drain plug- correct?
Is the fluid check bolt facing the passenger front tire?
Then you just measured 2.2 qts., and then filled from the top and did not check the fluid level from the fluid check bolt - correct?
Jack
Old Oct 27, 2019 | 09:01 AM
Riboflavin's Avatar
Wow sorry, I never actually paid attention to how crappy that diagram is lmao.
The drain plug is labeled D, it's on the bottom.
https://acurazine.com/forums/fourth-...k-bolt-968506/
This guy shows much better pics of where the check bolt is, it's on the front side of the transmission facing toward the front of the car
And you're correct, honestly, I don't even bother with it. I drain it, put in 2 full 1-qt bottles, then estimate 1/5 (0.2qt) to 1/4 (0.25qt) of the last bottle based on the measurements on the fluid bottle.
Old Nov 15, 2020 | 08:47 PM
Kingcredible's Avatar
Riboflavin, How is synchromesh holding up on your 4th gen 6MT? I also feel like i'm crunching gears in my 11 6MT. Would love to try your synchromesh recommendation. I found it as, "ACDelco synchromesh friction modified" is that the same one?
Old Nov 15, 2020 | 09:18 PM
horseshoez's Avatar
Latent car nut
Yes, that is the correct fluid for your gearbox; the proper part number is 10-4014.
Old Nov 15, 2020 | 09:37 PM
Thanks horseshoez. I'll make a video and upload it when it gets a bit warmer
Old Oct 23, 2021 | 01:27 AM
WDPanda's Avatar
My 4G had the crunchy 1st-2nd and odd 3rd gear as well. Sometimes had to double check if I put it in gear fully.
GM/AC DELCO Sychromesh Friction Modified fixed all of that.
Old Oct 24, 2021 | 04:11 PM
Riboflavin's Avatar
I just noticed someone asked me for an update a year ago.
Almost 2 years since that original post (3 years since I made the switch from OEM MTF) and I've still been running Synchromesh 10-4014 without a single shifting problem at all. It's gotten to the point where I completely forgot I used to have the 1-2 or 2-3 crunch every now and then.
Old Oct 28, 2021 | 05:44 PM
shurik74's Avatar
Thank you guys for info here! Ordered ACDelco as recommended cause I have the same first, second gear problems.
Old Oct 28, 2021 | 07:20 PM
WDPanda's Avatar
make sure the bottle says "Friction Modified"
i had Chevy tell me for sure it is FM and then because of reading these forums I stopped by GM to check and they had the proper one:
Left bottle - correct / Right bottle - wrong
Old Oct 28, 2021 | 11:20 PM
shurik74's Avatar
Appreciate your advice buddy... I ordered
Amazon Amazon
based on details from recommendations as part number is 10-4014 above which points exactly what you mentioned
The only difference is #10953509 number on your picture vs what I ordered. Is it still ok?
Old Oct 29, 2021 | 02:05 PM
Riboflavin's Avatar
Appreciate your advice buddy... I ordered https://www.amazon.com/gp/product/B0026JK8FK based on details from recommendations as part number is 10-4014 above which points exactly what you mentioned
I checked my Amazon purchase history, and that's the exact same link I used when I bought mine in 2019. So yep, that's it.
2.2 US QT needed for fluid change, 2.5 US QT for overhaul, so I bought 3 bottles.
Old Oct 29, 2021 | 03:21 PM
shurik74's Avatar
Perfect... Thanks for validation! Same here, ordered 3 bottles.
Old Nov 2, 2021 | 07:37 PM
Chris Carman's Avatar
8th Gear
I put amsoil synchromesh in my ‘14 a year ago and have been pleased
Old Nov 3, 2021 | 09:30 AM
RockAuto has one of the best prices, with shipping, & the applicable 5% discount code available in the vendor section.
More Information for ACDELCO 104014 (rockauto.com)
VanyDotK
Apr 3, 2018 12:37 PM
1Lieutenant
4G TL Problems & Fixes
Mar 25, 2013 06:02 AM
stavebomb
Dec 12, 2011 10:48 AM
acuradrvr2
1/2G MDX (2001-2013)
Apr 19, 2010 11:50 AM
mars
1G TSX Problems & Fixes
Nov 20, 2008 10:48 AM
