4g TL sh awd light showing up/ How to fix
Sauce God
Hey guys over the past years I have had the SH awd light pop up twice, and it completely disables by car XD, it only will give power to the fount wheels, and wont go past 4k rpms, Every time I get this code it is cause I either done have enough oil, Or I have to many ( My car leaks so its often found with either of these, I always clear the light and it goes way with no problem, You can go to auto zone or if you have one you can clear it yourself.
Keeping TL until 2029
Absolute guess...Coil Packs. I have a 2009 and I had to get new coil packs about 1.5 years ago. It lights up the dash like a Christmas Tree. Yours may be just starting to fail. I would check DTC as mentioned by @altair47
My car has been doing this on and off. I haven't pulled the codes or anything yet. I just take off the negative battery cable for about 10 seconds and it clears it. Not a good solution, but works in a pinch until I can sift through everything.
ostrich
12-02-2014 08:00 PM
CarrieLynn
06-21-2013 11:29 AM
