3x Transmission Fluid Change
Old 01-14-2016 | 06:52 PM
  #41
Reorge's Avatar
Originally Posted by hashbrown
I'm about to get my 3rd ATF change over. My mechanic says the filter shouldn't need changing unless replacing the transmission also. But i plan to do this as preventative maintenance. Since I'm not going to do the filter change at the time of atf changeover can this be done w/o a large amount of fluid loss? Does the line hold alot of fluid? I plan to either do the filter change right before fluid change or immediately after.
On my change out it's certainly less than a quart.
Old 01-14-2016 | 08:49 PM
  #42
jefflikesbagels's Avatar
I'm trying to find the correct pressure switches for the 2012 6AT, but I'm not entirely sure what's what.
Could it be the three #5 and three #6 parts? They're about $60 a piece, so they can get pretty costly.
From here: https://estore.honda.com/acura/parts...&dl=251445#004
Old 01-14-2016 | 09:44 PM
  #43
scottn3's Avatar
Scotch
Yes that's correct. This was a key component on the 5at for improving performance but I'm not sure if that still holds true for our 6at.
Old 01-14-2016 | 10:44 PM
  #44
Reorge's Avatar
Originally Posted by doggydog
I never did switch out the 3rd and 4th switch. Maybe that would of help, maybe.
This is the first I'm hearing of tranny switch issues on 4G. I think this issue has be solved by H/A over 5-10 years ago. Last summer I changed the switches on my ex-gf's 2005 V6 accord w/140K and it made very little difference.
If you decide to change them ...
4G 5sp (2011-AWD): Acura Parts @ AcuraAutomotiveParts.org - Genuine Acura OEM Parts from Acura Carland
4G 6sp (2012-AWD): Acura Parts @ AcuraAutomotiveParts.org - Genuine Acura OEM Parts from Acura Carland
Old 01-19-2016 | 09:58 PM
  #45
The one thing I've always wondered is why some switches fail faster than others? If you're driving in stop and go traffic, why wouldn't the first and second gear switches fail instead? It appears (for the 3G at least) that it's always the third and fourth gears.
For me right now it appears that fifth and sixth gears have the harshest upshift.
Old 01-22-2016 | 06:07 PM
  #46
Reorge's Avatar
The switch "labels" refer to the clutches, not the gears. And the clutch labels don't necessarily correlate with the gear labels. I don't recall off hand exactly but the in theory the 4th clutch could be part of the 5th or 6th gear activation, etc, etc.
orkoTL
4G TL Problems & Fixes
107
09-28-2017 10:12 AM
04tler
09-10-2015 02:13 PM
1Lieutenant
09-10-2015 09:39 AM
mav888
1G RDX (2007-2012)
09-08-2015 12:49 PM
jpm3071
NY/NJ
09-07-2015 09:25 AM
