2012 TL SH-AWD whining sound
So I have a 2012 Acura TL Type SH with about 110k. I just bought it at the end of July.
There is a whine that almost sounds like a belt that starts right as a go above 15 MPH, and stops when I drop below 15 mph. The sound doesn't intensify, change pitch or tone as speed increases, or RPM increase/decrease. Starts at 15 mph, and stops below 15 mph.
It's fairly faint, and my wife with super hearing only noticed it when I pointed it out to her. Just drives me crazy.
Any thoughts?
Any thoughts?
Check your trans fluid level and make sure it's changed regularly! You can also check and see how the brake pads are, if they are low or worn the squealer tab will touch the rotors causing a god awful racket. Other than that, there isn't much we can diagnose without more info. Was the 105K Timing belt and water pump service done? Oil consumption repair or factory engine?
eurTLove (11-04-2019)
many of us have had propellar shafts go out on these. sme of us multiple times. Have it checked by the dealer. HOwever if you record the sound and post it maybe we can get a better idea of what youre hearing. im hyper sensitive to my car now I have had so much wrong. I know all the sounds
LOL
LOL
also perhaps alternator...mine went out....could also be noisy tires....some aggressive styled treads can make humming whiney sounds. Also could possible be a very dirty Cabin Air filter. Since air cant pass through it forces air around edges and makes wind through window type howl...just thinking out loud here
gwdew
08-23-2014 11:45 AM
Napsoner
08-24-2006 12:30 AM
