??? 2012 Bumper Interchangeable with '09-'11 TL?
Old May 23, 2011 | 11:29 PM
3-2-1MUSIC's Avatar
7th Gear
Hey i'am wandering you can put 2012 bumper cover on 2010 tl if the can fit?????
Old May 23, 2011 | 11:37 PM
Bearcat94's Avatar
AZ Community Team
Int he future, a more descriptive Thread Title would probably be useful.
Old May 24, 2011 | 06:26 AM
ggesq's Avatar
3-2-1Music- Welcome to the forums. Hope you don't mind but I 'added' to your thread title.
Old May 24, 2011 | 06:30 PM
3-2-1MUSIC's Avatar
7th Gear
ty
Old May 25, 2011 | 01:50 PM
Mr Marco's Avatar
Has to fit. Hey 3-2-1, be sure to chime in under Regions, Northwest, All Oregon, and say hello.
Old May 25, 2011 | 02:39 PM
Nexson's Avatar
-Brian
jnc can weigh in on this one. I was about to do the front end conversion but got word that the bumper support and radiator support had different numbers. Jnc and I will do further research to determine if they are interchange. Obviously you will need the '12 grille assembly
Old May 25, 2011 | 06:47 PM
NwTSXmt's Avatar
fwiw...acura stated during a press release that there were no structual changes (spelling)...So let the cloning (clowning) begin..
Old May 25, 2011 | 07:18 PM
black label's Avatar
Trolling Canuckistan
Structurally they may be the same but if you go and buy a 2012 bumper it's not going to fit. The bumper itself is a different shape and so is the grill (the grill is also smaller from left to right). If you wanted to try this you would need the grill, the bumper and the trim that now goes around the grill. If you look carefully you will notice that the bumper goes up past the headlights near the grill on the 2012. On the prior 4th gen TL's, the bumper never came up above the headlights.
Old May 26, 2011 | 09:03 PM
Geez swaga's Avatar
G$$z Sw@g@
Hey guys wanted to chime in the front looks alot different so i dont think it will work but what about the back bumper does anyone know if it can be swapped from 2011 to 2012?
Old May 27, 2011 | 10:45 AM
potmilkz's Avatar
you have to get bumper and grill to make it work.. otherwise yes, it will fit... so to all you guys that get into accidents, ask the shop to get a 2012 front end lol! and if you have rear end damage, get the rear as well!
Old May 27, 2011 | 10:51 AM
Nexson's Avatar
-Brian
Is this based on assumptions or actual facts?
Old May 27, 2011 | 12:44 PM
gibjer's Avatar
Rowing my own
I'm going to go out on a limb here and guess the OP is trying to get rid of the grill for a '12 setup.
This will also require a new hood (the '12s extend further)
But the front lower bumper is 1" shorter then previous years so it makes sense that the beam is different as well.
Old May 27, 2011 | 01:56 PM
Treblig's Avatar
I'm not sure the hood is different. Acura did say that they made no sheetmetal changes. I think the "longer hood" appearance is a function of the body colored piece that is between the hood and the new grille.
Old May 27, 2011 | 03:55 PM
Nexson's Avatar
-Brian
Incorrect, the hood is the same size.
Old Jun 9, 2011 | 11:57 AM
potmilkz's Avatar
uh.. maybe because its just a slightly redesigned model with only bumper changes..
you really think that acura is going to modify the frame just to change the bumper.... i dont think soo....
all they did was change the bumper.. everything else is the same..
its like how acura had it interchangeable with 94 integras and 98 integras.. front bumper and headlights are interchangeable.. i can say the same for 95 civics and 99 civics..
this applies to much more cars that acura and honda made..
Old Jun 10, 2011 | 05:51 AM
Nexson's Avatar
-Brian
The bumper support maybe different to host the new bumper's shortened length.
Old Jul 9, 2011 | 01:17 PM
ANDYCHULOSKI09's Avatar
Welllll looks like I'll be one of the few to try this
Old Jul 10, 2011 | 08:49 AM
Nexson's Avatar
-Brian
Great keep us updated, it takes one of us to be the pioneer for the rest!
Old Jul 18, 2011 | 10:39 PM
Nexson's Avatar
-Brian
any updates?
Old Jul 21, 2011 | 06:16 AM
Need part numbers for everything but it's a direct swap had my boy at body shop confirm but thinkn of staying with 09 front cause of my Ron Jon grill
Old Jul 21, 2011 | 10:00 AM
ib_jimmy's Avatar
what about the bumper re-enforcement? wouldn't you think the piece will be different as well because the shape of the bumper is change?
Old Jul 21, 2011 | 10:32 AM
Nexson's Avatar
-Brian
I wouldn't confirm it until it is on the car. i would think that since the 2012 TL is shorter then the previous 09-11, that the bumper support would not stick out as much. thus if you put a 2012 bumper on a 09-11 bumper support, it would in fact push the bumper out.
Old Jul 21, 2011 | 10:36 AM
diddy_nyc's Avatar
I think it'll work. I'll scan the diagram for all to see. This would be a pricey mod.
Old Jul 21, 2011 | 11:22 AM
Prime Mover's Avatar
Maybe we should get Acura to recall all the 09, 10, and 11's because by changing the grills on the 12's they are admitting they were defective from an aesthetic point of view?
Old Jul 31, 2011 | 11:23 PM
aldehyde's Avatar
8th Gear
Question
Has anyone verified this yet?
Old Aug 5, 2011 | 01:07 AM
I_m_TL's Avatar
I'm interested on swaping the 09-11 rear bump on 12 body then I can get the RJ body kit!!
Old Sep 9, 2012 | 09:09 PM
jayan357's Avatar
9th Gear
Apologize for reviving such an old thread, but I did not want to create a new thread and get "l2search replies..."
I just got into an accident in my '09 TL (other driver at fault), and my front end is going to need replacing. I had an RJ grille >_<
Rather than get a new RJ grille and get it fitted and painted (Holy $$$), I was thinking I could just try to get the shop to install 2012 front-end parts. Does anyone know -exactly- which parts must be installed from the 2012 body? My fenders, hood, bumper, grille, headlights, and bumper support beam are definitely going to need replacing, but what about other, less obvious pieces?
Thanks in advance to any responses.
Old Sep 9, 2012 | 09:36 PM
potmilkz's Avatar
look up nexsons thread.. he has one created just for this swap.
he has done a 09-11 to 12 conversion with parts list. all you need to do is provide it to your repair shop with the parts number and it should all work well
Old May 26, 2016 | 02:11 PM
Guspena562's Avatar
2009 Acura TL
Hello everyone I'm new to the group & I don't know much. But would a 2011 grill, front and rear bumper fit on my '09? from what I've read it looks like it but can I have specifics on any modifications. And can I even put 2012 parts on it? Thanks !
Old May 26, 2016 | 02:24 PM
^i dont even have a 4G but just reading the replies in this very thread i came to the conclusion that
09-11 is the same. SO yes, you can do '11 on a '9.
and reading the same very exact replies, i came to the conclusion that you will need '12 bumper, '12 grille, '12 inserts, etc...
fuggin read!
Old Nov 21, 2017 | 07:45 AM
Kevin Abdin's Avatar
Exclamation 2013 Tl
Does anyone know if the 09-11 Acura TL “sports” grille can fit onto a 2013 Acura TL??
Old Nov 21, 2017 | 08:01 PM
TheMuffinMan's Avatar
If the normal grill isn't interchangeable without changing the bumper and such, why would the 'sport' grill?
I'm not even sure what you mean by sport grill...
Old Feb 19, 2020 | 04:16 PM
kelvin tran's Avatar
Hi guys, i know this thread is really old but i hope there are still people who are on here often to help me out.
I was wondering if it was possible to put the 2011 front lip on a 2012 bumper. I haven't seen anyone do it, so i wanted to confirm before i spent the money on the front lip
Old Feb 19, 2020 | 05:31 PM
You haven't seen it done because the bumpers are completely different shapes.
There is an OEM kit for the '12-14
quanaman
Jan 9, 2023 07:33 PM
08KBP_VA
Oct 22, 2019 01:55 PM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
BIGxRED
Oct 19, 2015 10:47 PM
rhdune16
Sep 28, 2015 11:31 AM
