2009 Acura TL Transmission Problems
5th Gear
![Exclamation](https://acurazine.com/forums/images/icons/icon4.gif)
Hi everyone, I’m new to the Acura world and let say it didn’t start off with the best of luck.
I just bought an Acura TL 2009 3.5L and I had the surprise to find that the transmission is defective. Let’s say I checked with 4 garages already and their recommendation is to replace the whole transmission. I do know a few basic things in mechanics but I have no idea how a transmission works or what needs to be done.
My questions:
Really appreciate your feedback.
My questions:
- What year transmission is compatible with my 2009 Acura TL? (from 2009 to 2014)
- Will it be easier and cheaper to replace the whole transmission or take the time to dismantle it and find the source of the problem?
- Do you, by any chance, know any good and reliable mechanic in Montreal area that would be able to help me with the situation?
- I read few post on the forum and one of them stated that I must reset the new transmission to the vehicle. Is that something my mechanic can do or I would have to go to my local dealership?
Gang Gang
My questions:
My questions:
Please inform this thread about what the transmission is doing and why it is defective that way if the transmission is repairable Acurazine can help you.
5th Gear
I will try to describe all what i hear and feel:
1. The transmission is slipping
2. The transmission is slow to respond when shifting gears (shifts at 3500 rpm instead of 2500 rpm on drive mode)
3. The RPM gauge sways even if the speed is constant.
4. While downshifting (from the 4th to the 3rd for instance) the transmission stays engaged in the higher gear for and extended period of time (over 2 secondes) before downshifting. Furthermore when it does a whining clunking sounds is present.
5. Even changing the gears with the paddle shift is poor and is not reacting normally and instantly.
LongLurkerTL12 (09-03-2020)
have you checked condition of the fluid? RPMS fluctuating at a constant speed usually means faulty torque converter... Make sure fluid is bright pinkish red and not burnt smelling. Get car to operating temp. Shut off car and within 60 seconds of turning off check fluid level. Should be between the 2 dots saying HOT. If it's low add more fluid I'd highly recommend OEM DW-1 fluid.
5th Gear
I will perfom the 3X drain and fill and get back to you about it.
How many gallons of fluid would it take for the 3X drain and fill as you recommended ?!
Also, make sure you get crush washers for both the drain and fill side. You can just get one set and install them after you perform the last service.
If you need help on how and where both bolts are located i can send pics. Make sure you get the fill bolt off first just in case. Sometimes it won't come off and you'll be screwed if you drain all the fluid first.
I just get a 3/4" drive with a 12" extension and that usually breaks it loose just fine. Good luck and hopefully that will solve it!!!!!
5th Gear
Hello everyone,
I just wanted to let you know that the problem was resolved
what happened is that there was a leak between the radiator and the transmission oil.
so I had to fix that and then flush 5 times the transmission and decontaminate the radiotor and the transmission.
Now the car runs very smoothly, I'm finally enjoying my Acura.
Thank you guys
Thank you guys
The following 2 users liked this post by Yous:
LongLurkerTL12 (09-13-2020),
Reorge (09-13-2020)
Hello everyone,
Thank you guys
Thank you guys
S2000 Driver
4G TL Photograph Gallery
01-01-2009 10:54 AM
whoaclutch
10-27-2008 10:40 AM
