Type S...NO SPARE! Self Sealing Tires...!!! WTF??
I don't know IF this has been brought up anywhere...BUT, I just discovered that the Type S has..."SELF SEALING TIRES".....AND, with that said....
NO SPARE TIRE!!! Well, IF I were a maybe buyer for a Type S, that would be a deal breaker for me. Self sealing tires???....doesn't help with a
sidewall issue...blowout, etc. You're still screwed. And the battery is in the back left side floor area. I can live with that....but, not the spare tire issue.
ALL MDX, RDX's with AWD always had/have spare tires...as the '22 MDX's still have...EXCEPT now the Type S.
Added note: My dealer has a Type S Advance due in soon. It's a "show and tell" model they have to..or supposed to keep for 60 days to allow
possible buyers to review, drive, etc. This happened with TLX Type S's....but, many dealers sold theirs real quick. My dealer did not. They chose
to follow Acura's directive to keep on lot to show off. They will do the same with this new model.
Stay Out Of the Left Lane
I guess we'll see how they are. This was the one feature I was not excited about with the Type S.
Yes, but I was thinking for those pesky "nail in tires" having a spare would allow me to drop the tire off for repair and not have to leave the vehicle there. But uh with that said can these run flats be repaired for nails or even need it?
"The MDX Type S is the first Acura with standard 275/40R21 ContiSeal® high-performance tires. ContiSeal tires are specially engineered to be self-sealing for tread punctures up to 5mm (1/4 inch) in diameter. There’s no need to stop, repair or replace the tire – it can be used normally for up to 10 years. The standard Tire Pressure Monitoring System (TPMS)51 helps you confirm that all is well."
to do the same with the new MDX?? But, still....at over $70K....to put a "self sealing tire" on it is BS. How about your wife out at night and the sidewall blows out....it's happened...
to us....what is she to do then...esp. if in a bad area? I know...having a spare may not "save the day"...but, I'd rather have the spare than not.
Deal breaker...yes, IF it's not doable to buy the spare, all the parts and it all fits properly. ??? The RDX does....BUT, the MDX has the battery in the back now....and we don't know
if the underside is "shaped" the same so a spare can be held up in place like the std. MDX?? Just things to think about. Not my first rodeo with these kind of issues.
The '22 MDX, NON Type S's, DO have a spare from the factory....and the previous yrs did too...as long as it had AWD. I know the FWD never did come with a spare.
I've owned them all. Even the '22 MDX Adv!! Yes, I already traded it for the RDX A-Spec/Adv for my wife. She likes the easier to handle size. I loved the MDX. Anyway....the 2 Type S versions are the only '22 MDX's that DO NOT have a spare...speaking of AWD models as just discussed.
Hopefully, you can add the spare tire kit hardware from the +22 3.5L MDX to the Type-S MDX. Might have to see if the wider full size spare tire will fit snug enough under the Type-S or if you will have to go with a donut. Adding the spare tire kit and full size spare is what I had to do with my 19 MDX hybrid that only came with the 12v fix-a-flat air compressor thingy. The Acura service manager didn't know the hybrids could take a full size spare or OEM hitch/harness also would fit on the hybrid. They thought the hybrid battery pack would be in the way if you try to add the hitch or spare tire.
Might have to check under the Type-S MDX for room because the extra features like air suspension components or new exhaust system need to be stored somewhere under the vehicle and be able to add an OEM hitch+harness+hands free kick open feature.
I totally agree with Colorado Guy - run flats & no spare = no sale. What hasn't been mentioned yet is that run flat tires have a tendency to provide a harsher ride and many people dislike them. Also - very few tire distributors have them in stock "just in case" someone needs one. That leads to a problem if you blow one out in the middle of nowhere. You're dead in the water even if you have AAA or some other road service because it may take 3 days or so for them to aquire a replacment tire for you to be able to continue your trip.
So, if you really don't want the runflats but like the vehicle that leaves you with the proposition to trade them in for regular tires AND purchase a spare tire kit at your own expence -----------!
Run Flats vs Self Sealing
FYI - here is a brief article describing Self Sealing vs Run Flat (self-supporting) tires. I also saw another article in more detail about Run Flats being much heavier and less durable than Self Sealing. May not be ideal - but Self Sealing seem much better than Run Flats.
https://www.tirerack.com/tires/tiret...s&gclsrc=aw.ds
Wylson (07-31-2022)
I stand corrected in using the term run flats as opposed to the self sealing tires supplied on the Type S. They aren't the same. The self sealing will help with most small puntures in the tread area. The self sealing portion doesn't extend to the sidewalls, so damages there will result in a flat just like normal tires. If you have one of those type of damages you will still be unable to continue your trip because you have no spare and again, just like run flats, they aren't as readily available in tire warehouses so you may have an extended wait for a replacement. I have experienced sidewall damage on the road and have had a spare to keep me going. This is something that I would prefer to have "just in case". So for me, self sealing tires and no spare = no sale without obtaining a spare tire kit assembly.
Wylson (07-31-2022)
Maybe the Type-S have a shorter rear bumper panel that shows the spare tire more compared to the 3.5L MDX. A Type-S owner might have to add the OEM hitch to see if that hides the spare a little more. Adding the OEM hitch helped hide my full size spare a little bit better on my 11 MDX Adv and 19 MDX hybrid.
