Slight misalignment of the hood
Old Jul 16, 2021 | 07:07 PM
Li’l Red's Avatar
5th Gear
Hi. New member here but not new to Acura.
I bought a ‘22 ASpec 2 weeks ago and just noticed that the hood is misaligned slightly such that the center line on the hood is not in line with the centerline of the hood extension (the little piece that is separated from the “main hood” of the vehicle). So does anybody else have a problem with the hood being misaligned? And if you have, what did you do to remedy it aside from taking it back to the dealer? (Mine is 4 hours away). Thanks
Old Jul 16, 2021 | 08:11 PM
take photos and post it here and maybe i can help.
if you want to tackle this task, you're going to have to re-adjust things...so, whatever you called the "extension" whatever that is, you may have to adjust it.
Old Jul 16, 2021 | 08:15 PM
i understand now...
Old Jul 16, 2021 | 08:16 PM
if the "extension" lines up with the front bumper, then the misalignment is with the hood. and you will have to either adjust the bolts to the hood or add spacers to the hood to get it to line up with the body.
Old Jul 16, 2021 | 08:19 PM
or just take it to the dealer.
Old Jul 17, 2021 | 09:09 AM
Li’l Red's Avatar
5th Gear
Old Jul 17, 2021 | 09:12 AM
Li’l Red's Avatar
5th Gear
I think the front of the hood needs to be moved just slightly to the right (when looking at the vehicle) but I don’t know if there’s a way that I can DIY it. Regarding the dealership, I’d take it back there if it wasn’t a 4-hour drive to the dealership.
Old Jul 17, 2021 | 10:08 AM
I think you may need another set of hands.
the adjustment bolts are at the hinge. you would loosen the bolts to see if you could get it to line up better....then tighten the bolts down
Old Jul 17, 2021 | 11:28 AM
Li’l Red's Avatar
5th Gear
this is on the driver side
Old Jul 17, 2021 | 11:46 AM
yes, if it were my car, I'd get an assistant to help me adjust the hood.
Old Jul 17, 2021 | 11:50 AM
Li’l Red's Avatar
5th Gear
I wonder if I would also need to adjust the hydraulic rods
Old Jul 17, 2021 | 11:54 AM
i believe the struts or hydraulic rods are predetermined.
anytime adjusting doors or hoods, it might take a few tries as any slight movement will throw the alignment off.
Old Jul 17, 2021 | 11:55 AM
i would also use painters tape to tape up all the edges, any slight "oops" will result in chipped paint.
if you have any old blankets, i would drape them over the fenders and grille and headlights
Old Jul 17, 2021 | 05:48 PM
Edward'TLS's Avatar
6G TLX-S
As for the hood-to-fender gaps, do you have a bigger gap on one side than the other side ? If both gaps are the same, you won't have room to adjust the misaligned hood at all.
Old Jul 18, 2021 | 08:48 AM
22MDX's Avatar
I don't understand why so many on this Acura forum are so tolerant of poor body gap alignment on many Acura cars and SUVs. Acura called itself a luxury brand but its panel fit is worse than many domestic non-luxury brands. My current 22 MDX also suffered from poor body panel alignment. This is not excusable. No amount of reliable hardware in this car can make up for the poor workmanship. My previous bad experience is with a 2018Honda CRV make in Mexico.
Old Jul 18, 2021 | 08:52 AM
not tolerant buy buys more honda products. lol
it's okay, it's not the end of the world...a little adjustment is all that is needed
Old Jul 18, 2021 | 09:59 AM
moose66's Avatar
Agreed. I find it funny reading this forum the responses of some. I’ve seen people send back a $10 hamburger if not prepared to their liking. But here we are reading about people trying to figure out, some on their own it appears, how to realign some out of sync body parts on a 60K car. Really? If you aren’t happy with your purchase, take it back. I sure as hell would. Wouldn’t attempt to anything on my own. You mess it up, it is on you. They mess it up, it is on them. And it is on them from the start anyway!
Rev_Joel
5G TLX Problems & Fixes
24
Oct 21, 2021 10:43 AM
05TLdcc
Mar 15, 2010 03:10 PM
732xghost
Sep 11, 2006 11:14 AM
Tsex on 19s
Nov 25, 2004 09:15 PM
Duece
Jul 23, 2004 12:21 AM
