Work DR(
Work DR(
So i decided its time to start changing my car up a bit (getting tired of seeing my care stock lol), so far i got my self BC coilovers, waiting until the snow melts to put them in, now i'm shopping for some wheels ...
I was looking at getting Work DR9, i believe there the replacement for the XD9's, i cant find too much information about the setup people have done. I think i know what i want but i'm nervous about if it will clear my calipers or not
Specs of wheels i wants to do (looking for an aggressive look):
18 x 9.5 +23 (Front)
18 x 9.5 +12 (Rear)
For the rears i'm almost sure i'll need to put a small spacer to clear my calipers, but will the front fit without anything?, i am going to roll my fenders to make them fit better ... any opinions?
18 x 9.5 +12 (Rear)
Janagan_ua7 (02-03-2015)
Thanks a lot man, that helps, so it looks like i might go ahead with these specs, i was worried about not clearing but looks like i will with some poke, good to know, btw your car looks great
^i like my set up square....meaning; all 4 corners are the same.
the fronts will be harder to fit a more aggressive spec'd wheel because you have less room to work with.
and check your specs....you are wanting to do a more aggressive set up than I have on.
which means, you will poke until you drop + camber it out + fender roll + cut fender tab.
justn you're running 18x19.5 all around?! you're an inspiration to even the hellaflush/stance guys!
OP, you're not going to have any problems with those specs in terms of caliper clearance. You're going to have a tough time fitting those wheels under your fender though.
The following 2 users liked this post by xtcnrice:
Janagan_ua7 (02-03-2015),
justnspace (02-03-2015)
mada51589
05-03-2022 08:54 PM
Luis J. Rodriguez
09-12-2015 10:00 PM
ahsm
09-09-2015 08:35 AM
