Winter tires put away without marking which was which
Confusing title...
I bought a used set of winter tires/rims. Is there a way to check which tire is which so I know where i should place the tires as far as rotation?
im clueless on tires
are they DIRECTIONAL tires?
meaning is there an arrow on the tires, indicating which direction the tire is supposed to roll?
if not, you can put the tires on in any direction/any combination.
Since you bought the set USED, you wouldnt know if the previous owner rotated them properly.
all you can do is put them on and use them.
Make sure they arent directional tires.
rockyboy
08-04-2024 10:35 AM
