Will these snows/rims fit my 2004 TL properly?
rims/tires i am looking at
Size 17X7.5Offset: +45mm Backspacing: 6.10" Bolt Pattern: 5-112
Rec. Tire Size:225/45-17
proper specs for the TL
Offset: +35mm
Backspacing: 5.66"
Bolt Pattern: 5-114
Rec. Tire Size: 235/45/-17
Offset: +35mm
Backspacing: 5.66"
Bolt Pattern: 5-114
Nope, you answered your own question. Adapters are available but hardly worth the cost as it would be better just to find the correct dimensions, or if cheap enough, purchase the set and sell the wheels.
Actually the proper specs for the 3G TL is:
17 x 8 +45MM offset 5x114.3mm, or 5x4.5"
solace in privation
Im looking at a set of Dunlop snow tires 205/50/17 . will these fit on my stock TL rims. I have an 06 6mt? Tire rack says max with 7.5. thanks for any advice or help in advance.
EvilVirus
12-10-2015 07:38 PM
