Will these fit?
Will these fit?
Volk SF-Winning f19x8.5 +38 r19x9.5 +42?
What do you think? I think the fronts would be fine its the rear I would be concerned about.
If not I think I am just going to go with some enkei 19" rpf1's that I know will fit with a +42 offset and width of 8.5"
D
D
Originally Posted by terry919
I have the exact rear setup. Just go with 245/35 tires front and rear and you will be fine.
D
94 DC4 RS LSV/Turbo
oh you wanna run meaty... 255/35-19 works too, but 265/30-19 works good too, but for the rear it wont affect speedo anyway so it is no real priority... as far as affecting the vsa/abs you'd be ok with running 265/35-19 for that matter
Well I went ahead and pulled the trigger. I paid $2719.99 for them but I will be getting back $250 due to the cash back thing. So in the end it will cost me $2469.99 and shipping is free. Now for tires.....HA
http://cgi.ebay.com/ebaymotors/ws/eB...m=130233264560
These are the exact wheels I purchased.
D
D
Originally Posted by rodneyc77
those wheels look real dope... Good Luck
Also I am not too familiar with these wheels. Do you think my TPMS will bolt right up or will I have to get some kind of adaptor kit (like iforged adaptors) to make it work?
D
SlammedOnKonis
D
D
Thanks man I messaged the seller to inform him what my car is so I get the correct hubcentric rings and stuff and he replied back great and that they will ship out today. So hopefully that means I won't have to wait a long time to get them.
D
D
Also, I highly recommended you to get 245/35/19 tires all around. You don't even have to roll the fender if you go with that size. There is no point of running 265 at rear on a fwd car. You are just wasting money and getting more trouble on yourself. You will need to roll your fender and it might still rub if you rear doesn't have enough negative camber.
The TPMS won't fit on the rims. You will need to get the Iforged adapter in order to mount the sensor. $90 for a set of adapter.
D
Btw are you sure that running a larger tire than a 245 will result in rubbing? I only plan a mild drop of maybe an inch or an inch and a half.
D
D
Might or might not.... it really depended on the camber after you drop the car. 255 will be fine, but I am not sure about 265. Also, you should go with smaller tire and shoot for the stretch tire look if you wanted to get the vip look.
D
TheModCity is the only place I found that carries them but they say I need the bracket.
http://www.e90post.com/forums/showthread.php?t=75817
There is a link to them I thought the 1st picture would be the ones I needed but am I wrong?
D
Which adaptors should I get?
D
D
D
20s?
i just put a set of 20s on my 08 and found a perfect tire fit 225/30/20. now i need a TPMS sensor that will work in the 20 or a good bypass for the system all together any ideas?
Ok I have the 265/30/19 tires for the rear already now I wonder if I should go with 235 or 245 up front. I am thinking 245 to keep both ends closer than further part in size. Anyways opinions would be nice.
D
D
emailnatec
29
09-28-2018 04:27 PM
xsilverhawkx
09-28-2015 06:51 PM
