will this set-up work?
Originally Posted by Fulani has a TL
Front will work, You Can run the rear without rolling if you run 245s on the tires.
OHHHH, you got a 6spd. Well then, IDK. The back is gonna be close. Ill tell you im running +35 with 245's and I will have to roll if I go any lower. Which I do plan on it, going in for a roll session tomm.
front need to get advice from 6spd ziners, Im a 5AT guy. Sorry
It depends on the wheel. Even if the offset is ok, the spoke design may be such that it doesnt clear. Unless someone here has actually mounted it on their 6-speed or TL-S, there is no way to tell you for sure.
Thanks guys. I think the best thing for me to do is go 19x8.5, +40 fr and 19x8.5, +34or +37 rr. That way I don't sacrifice my handling. My other option is 19x8.5, +40 fr, 20x9, +40 rr. This really fills the rear wheel well, gives you a wider lip and doesn't affect the handling nearly as much as 9.5 or 10.
ahsm
09-09-2015 08:35 AM
