will bigger wheels make the car lower?
Peach Tea
People keep telling me if i put my 18s on, the car will be lower. I didn't think this was the case tho. some kid at my school had 19s on an accord, with stock springs and it was extremely low. I'm trying to decide if i should put my H&Rs on or just the wheels. someone help me out.
Peach Tea
Originally posted by rhizopod
Think about your question for a minute. You should be able to answer it yourself.
the reason i am confused is cuz ppl on here with bigger rims and no drop have cars that look like SUVs, but i've seen cars with wheels and no drop look lower.
can someone post a useful answer?
thank you
Assume your current tire/wheel combo has a total diameter of 20". Replace it with a tire/wheel combo that has a total diameter of 24". They both bolt onto the car at the same place..... so, badazztl, what happens?
Peach Tea
I'm going to help you figure this out on your own. You'll be kicking yourself when you get it.
Visualize the 20" total diameter tire/wheel combo (for examples sake, let's say a 16" wheel with 2" of tire all around) mounted on the car. It is mounted at the wheel's center, so 10" (8" of wheel and 2" of tire) extend to all points from the center (hint: this includes the GROUND).
Now visualize jacking up the car, taking that wheel/tire off, and putting on a larger wheel/tire combo. Let's say an 18" wheel with 2" of tire all around for a total diameter of 22". You mount this wheel in the same place as the previous wheel/tire combo (you must, since you mount wheels at their center). So you now have 11" (9" of wheel and 2" of tire) extending to all points from the wheel's center (including the GROUND).
So, what has just happened?
Peach Tea
i hope im right lol.
its summer time and my brain is working too hard for now and i dont appreciate it:p
6th Gear
this might help:
Try selling your TL and signing up for a community college geometry course. Maybe that will help.
ALL THINGS BEING EQUAL, IF YOU PUT ON BIGGER (OUTSIDE DIAMETER) TIRES, THE CAR WILL GET TALLER.
Moron.
Moron.
um...the overall diameter or out stock wheels/tires is around 25inches correct?....if we got 19s...were sitll shooting for 25inces in overall diameter...so i dont think your explanation really works...i too..dont understand how bigger rims make the car seem higher (esspecially in fender clearence) when the overall diameter is the same...
to confuse you further, the overall diameter (tire sections plus rim diameter) of the new setup should be as close as possible to the stock setup. doing so prevents mileage or speedo or abs errors. if you think about it, the car is not any higher or lower but it will appear to higher when you look at it. this might stem from the fact that most new wheels are mounted farther out (due to lower offset and wider width compared to stock) or the combo of a skinny tire and open wheel face or less sag in the suspension and stronger/thinner tire sidewalls. maybe a figment or our imaginations???
but to answer the above question...the car is higher up if the rolling diameter is not kept in mind. bigger diameter than stock, car sits higher. smaller diameter than stock, car sits lower.
Peach Tea
Re: this might help:
Moron.
Moron.
no need for me to sign up for a geometry class, i already passed with a B in high school like 2 yrs. ago
oh, and i dont think you make sense either b/c with bigger rims, i got a lower profile tire, so overall the size of rims and tires will be the same, thus not having an effect on height of the car. now fu(k off NOOB!
Re: Re: this might help:
Peach Tea
i take back what i said about me being stupid
:p
Originally posted by njtls
he was asking why even with the same overal diameter it still looked higher which stanman helped explain
:p
:p
Peach Tea
No he wasn't. Read the original post. It's says nothing about maintaining the overall diameter.
Ackniculous One
I have 18" wheels with no drop on my Accord. My TLs is still taller.
If you stay close to stock overall diameter, your car won't be necessary taller, but you may experience the fender gap illusion. Since I took the Eibach springs off my accord and went back to stock, the fender gap really ain't noticeable. I'm into comfort these days anyway. Now, if you put 20's on your car, that is a whole new thread.
