Will 275/35/19's fit?
I have an 05 TL with stock suspension. Will 275/35/19's with a 35 offset fit in the rear without rubbing on the fender and if they do fit how much do you think they would stick out. I just love the way the car looks when it has really wide tires on it.
Originally Posted by rondog
No, 245 barely fits because the sidewall is almost vertical, with 275, the sidewall wil;l bubble out past the rim lip which is already past the fender.
Turd Polisher
If the tire is too far past the fender, it will rub. 275 is huge.
I want to see the car with HRE / 275-19s. .
BORICUA
Here https://acurazine.com/forums/showthr...5&page=5&pp=25 you can see a 275/35/19 on a car.Conan777. He said he had rubbing issues and is not even drop. I had 20x10 in the rear with 40 offset and I had to roll the fenders using 255/30/20 tires. For a 9.0 inch wheel you should be fine with 255/35, 265/35 tops.
all work and no play
I have 265/30's with a 19x9.5 on mine with stock suspension, I cant remember the offset tho I think it was either 40 or 45...I just checked my paperwork and its not listed, but Ive never had a rubbing issue
So if you are fitting 265's with a 40 or 45 offset and not rubbing. Shouldn't I be able to fit a 275 with a 35 offset on there without rubbing? Is it the lower the offset then the more room you have in the wheel well?
BORICUA
The lower the number the more the wheel will be pushed out. You can play with the offset here http://www.1010tires.com/WheelOffsetCalculator.asp
And with the tire size here http://www.1010tires.com/TireSizeCalculator.asp
Originally Posted by stillhere153
with a 35 offset without rubbing you will have to go with a 255, 265 will definitely rub... or just get the 275 and roll them fenders
Do you think it would rub if I went to a 265/30/19 instead of a 265/35/19?
emailnatec
29
09-28-2018 04:27 PM
xsilverhawkx
09-28-2015 06:51 PM
