WIll 18X8 with 40mm offset work?
its on an ebay auction and the guy has 1000+ feedback and he says it will fit. will it fit if i put on smaller tires? and i'm on stock height... maybe if i get them and they dont fit i can report him to ebay?
...and then there was One
If you really want them, buy them, then grind off 10mm off the inner hub. That will give them a 50mm offset... as long as the wheels are strong enough to grind 10mm off (what is that, 1/3 inch?).
![Thumbs down](https://acurazine.com/forums/images/icons/icon13.gif)
I strongly suggest you don't go with 18X8 w/40-mm. I have the same specs on my rims and haven't trimmed the bumper tab or dropped it yet. I get occassional rubbing when I have people in the back on certain roads. I would shop around a little more and get 18X8 w/50mm offset if you want to stay with the same diameter and width. IMO, the less trimming you have to do on the car or the wheels the better.
Moderator Alumnus
Originally posted by TL_LiFE
**snip**IMO, the less trimming you have to do on the car or the wheels the better.
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
