Wider wheels ... aggressive fitments?
Old 12-13-2011, 12:20 PM
Blakvrtbeast's Avatar
need some input from all the guys that tend to run more aggressive fitment. My current set up is 18x9 +30 and 18x10+30 with a 225/40/18 and 235/40/18. The car is lowered on Tein basics and i have rolled fenders all around and have 0 rubbing issues. I want something a lil wider and im trying to see if i can get away with like a 18x10.5 in the rear with no rubbing issues or crazy camber stuff and also go a lil wider in the front as well. thanx in advance guys !
car for reference...
Old 12-13-2011, 01:19 PM
takin care of Business in
swoosh's Avatar
Received 4,732 Likes on 4,064 Posts
PM K.R.E.A.M, Grapejelly, jptl04, bforbrian for fitment questions....
they are slammed/aggressive offset/wheel whore's LOL...
Old 12-13-2011, 01:28 PM
murph145's Avatar
yea you can go wider and a lil lower
do you want to stick with 18" rims??
go a 1/2" wider up front and back rear with same offsets and you will be golden. otherwise throw on a 5-10mm spacer see how you like it and if it rubs.
Old 12-13-2011, 04:04 PM
yeaa im sticking with 18's since i live in NY haha and i daily drive it... i will most likely end up putting 5mm spacers on and seeing how it goes from there, hopefully the other guys will chime in
P.S. im selling the wheels if anyone is interested
Old 12-13-2011, 04:08 PM
murph145's Avatar
remember 5mm spacers only make like a 1/4" difference so its not going to be a huge OMG change.
it just depends on the look you want and how much camber you want to run if you go 1/2" up on rim widths front and back with same offsets that is pretty much as far as you can go with only rolled fenders and like -2/-3 camber
Old 12-13-2011, 04:15 PM
bforbrian's Avatar
You'll be surprised at how much more room camber kits will give you.
For the rear, you can get away with 10.5 ET15-22, maxed out on camber.
For a 10" wide rear this about 18x10 ET10-15
I would just throw that 18x10 +30 up front and order a wider set of rears with lower offset.
Old 12-13-2011, 05:26 PM
murph145's Avatar
^ very true but he doesnt want to run "crazy" camber.... not sure what crazy means lol but probably nothing more than the natural camber from being lowered I am assuming
Old 12-13-2011, 05:32 PM
rhafikjaan's Avatar
18x9.5 +30 with a 225/40/18
18x10.5 +30 with a 245/40/18.. is perfect
Actually even this it still depends on how lowered you are.
Old 12-13-2011, 11:09 PM
i want to keep the stock camber that i will just get from lowering the car , as far as putting the rear wheel on the front cant do so b/c of the brembos and im also selling the wheels. I put on some 10mm spacers on front and back tonight and no rubbing with someone in the car , so i guess the new set up will be the same 18x9 and 18x10 just different offset and same tires. If i put a 245 in the rear im sure it will rub
1fatcrxnem1
22
06-01-2018 01:23 AM
KB1_EJ6
11-13-2016 09:51 PM
PortlandRL
09-14-2015 12:01 PM
nuldabz
09-03-2015 05:49 PM
Quick Reply: Wider wheels ... aggressive fitments?
