Wider tires up front.....
In the 1/2005 issue of C&D, page 37 they review the new Pontiac GXP which will have a V8 with 290hpw/325lb-feet through the front wheels. To combat the power, they ( Pontiac ) are mounting 255/45/18's on 8" wide wheels on the front and 225/50/18 on 7" wide in the back. They state that this will decrease understeer and balance the chassis.
I know it won't look great, but will this decrease understeer and create a more balanced feeling in our chassis?
Say it did work, maybe just adding a slightly wider tire up front, say 245/45/17 on the front stock rim might add a benefit without upsetting the looks of the car.
Thoughts...................
It sounds like a decent idea but wouldn't a thicker rear sway bar achieve a similar effect WITHOUT adding unnecessary unsprung weight to the front wheels? The extra seveal pounds of rubber will rob performance to some extent. At least that is my take on the situation.
dsc888
dsc888
dsc888
dsc888
Registered Member
To ZQQM;
Don't go to 245/45-17's. You'll lose acceleration because the tires are taller. This had the same affect as going to a higher final drive.
Instead, use 245/40-17's.. or even 35-17's.
ImayBparanoidButNoAndroid
Here's a question.
If going with wider tires up front does help, witch it makes sense that it would, does using the same width tire in the rear affect or negate the performance increase of the front tires? What I'm saying is why not just increase the width of all the tires? I understand why having wider tires on the driven wheels helps, but does having the same width tires on the non-driven wheels hurt?
Originally Posted by automata
Here's a question.
Putting wider tires on all 4 corners won't address the issue mentioned above.
Here's a question.
09-17-2015 09:01 PM
09-15-2015 06:44 PM
