Why you should get 255/40-17 tires for your OEM rims !!!
Old 02-17-2007, 08:48 AM
  #201
3rd Gear
TASAVOY's Avatar
Originally Posted by EnvisionTL
I read through 8 pages but did not see any of the people running 255/40/17 shoes mention anything about whether or not they lowered their cars. I think there was one post about a member wanting to drop their car with this setup but I did not see a followup. Has any of the people running 255s lowered their cars? Thanks! btw the wider tires look great!
My o5 tl is lowered with H&R coilovers set at 2.5 inches lower than stock on conti extreme contacts 255/40/17.There is no rubbing in the front when making turn or in the rear.
Old 03-12-2007, 07:53 AM
  #202
Ghost Rider
Ghost-Rider's Avatar
Ventus HR2
Just thought I'd provide a little more input on this subject. I do onsite tech support in Austin, TX, and I use my TL for all my driving, so I do quite a bit of mileage (23,000 in 2006). At 42,000 miles I needed new tires, and after reading this thread I thought I'd try the Ventus HR2 255x40x17 tires from Discount Tire Direct. Everybody seemed to have glowing reviews and they were only ~$80 each delivered to my door.
I've had them on for a week now and they are great. I was a little skeptical when I read the comments about being able to feel a difference, but I have to say, the car does drive differently, a little more smoothly perhaps. They are also very quiet tires.
I drove C5 Corvettes before this and I had to smile when I realized that at 255mm, my new TL tires are actually 10mm wider than the front tires on my 2000 'vette used to be
So add me to the list of the converted!
Old 03-12-2007, 05:03 PM
  #203
I like to whistle in my
Meek32v6's Avatar
this is nice to hear...waiting on refund check to get my new tires
Old 03-12-2007, 06:07 PM
  #204
Be kind to us truckers !
007TL-S's Avatar
I wonder if this tire size will work on my TL-S?....I think it woud?
Old 03-12-2007, 10:41 PM
  #205
Meek32v6's Avatar
I dont see why not???...they are 17x8 too, right?
Old 03-12-2007, 11:37 PM
  #206
Inaccurate's Avatar
^^^ Ditto. The 2007 Type-S has the same rim specs as the earlier 3rd generation. I will "go out on a limb" and say that the 255/40-17 will fit perfectly.
Old 03-13-2007, 12:03 AM
  #207
Inaccurate's Avatar
I got some lightweight rims two weeks ago. The rims have the identical specs as the factory rims (17x8 with 45mm offset). The only difference is that the new rims are much lighter.
Here is a pic to keep you updated. These are my same tires that I had since the beginning of this thread. Same rubber, just different metal.
Old 03-13-2007, 12:13 AM
  #208
Inaccurate's Avatar
Old 03-13-2007, 02:08 PM
  #209
Jeffa1's Avatar
I like your new wheels. Real nice. And the tires look like they're wearing pretty good.
Old 03-13-2007, 10:51 PM
  #210
Modding my TL in
xcelir8TL's Avatar
Are you sure 255 will go on a car with Tein lowering springs like mine?
Old 03-14-2007, 08:54 PM
  #211
Inaccurate's Avatar
No, I do not know if the 255's will clear on a lower TL. Hopefully, someone with firsthand expereince will chime in to help.
One quick way to get a rough idea is to look. Can you place your thumb between your current tires and the fender well ? The difference in the 235 versus 255 should be approx the width of a thumb. Turn the steering wheel a little at a time, and check for "thumb" clearance as your turn the wheel.
This rough clearance check does not account for suspension travel however. Shrug.
For what it might be worth, mine has Never rubbed anywhere while going thru dips in the road.
My TL looks like motorcross suspension compared your yours.
Old 03-14-2007, 09:05 PM
  #212
Inaccurate's Avatar
Dooh... composing a response within the 5 minute edit window doesn't work too well.
When I said "My TL looks like motorcross suspension compared your yours", I meant this in a nice way. Your lowered TL looks great. Mine sits up high because I removed a lot of weight.
Old 03-19-2007, 10:15 AM
  #213
Computer Techie Geek
Pankul's Avatar
how about 255/45/R17
Inaccurate: I have been following you post for a while now, and finally the day has come. I need new tires. However I cannot get the Summer Tires as I am in NYC Area, where we get worst of both weathers. All Seasons is my deal.
I am seriously looking to get the 255/45/R17 for my stock rims. I like the Width on 255 but I am not crazy for low profile, and care for more treadwidth hence 45 seems optimum to me.
What are you insights just cos you seem very knowledgable and experienced. This is my first car, and first Tire change
Old 03-19-2007, 01:52 PM
  #214
Pankul's Avatar
just found your comments about the same already, so I answered my question ...
feel free to add anything else...
Originally Posted by Inaccurate
Let's compare the 255/45 to the 255/40 -
10) HIGHER effective gear ratio (sluggish)
9) REDUCED braking force per given pressure on brake pedal (brakes feel less powerful).
8) Slightly HIGHER stance (estimating 1/4 inch)
7) Great rim protection without being excessive (this remains the same).
6) With the 255/45 tires, TL now looks less sexy (bulky profile)
5) You will be less envious of others having A-Spec (debatable)
4) Having wider tires than a G35 (this remains the same).
3) Car feels HEAVIER (accelerates sluggish, brakes sluggish, less responsive steering)
2) Don't need to stay 10-feet away from the nearest curb anymore (this remains the same).
1) TL now looks plain 'ol "mean" as heck, but with a bulky profile.
Old 03-19-2007, 11:40 PM
  #215
Inaccurate's Avatar
If you really like the 255/45 size, I say give it a try. IF you prefer the look of the 255/45 and do not mind the disadvantages, I say give it a try. Who ever you get the tires from, ask them if you can return them if you don't like them once mounted. Many places allow you to change your mind after seeing the tires mounted (obviously with few miles on the tires, if any miles at all).
Old 03-20-2007, 01:34 AM
  #216
Team Anthracite
tidus888's Avatar
the legend of our TLs
team honda research acura TL
uses 255/40/17 on 17X8 rim
http://www.hondanews.com/categories/793/releases/3081
Old 03-20-2007, 03:07 PM
  #217
Pankul's Avatar
Lightbulb Another cool website for TIRE SIZE Calculation
has graphics, uses JAVA
http://www.miata.net/garage/tirecalc.html
Other link that has been posted before (for your reference)
http://1010tires.com/TireSizeCalculator.asp
Old 03-20-2007, 04:31 PM
  #218
JLim's Avatar
hi fade, which brand of tires did you go with?
& how do you like them?
i like the look of the 255/40s on the rim by itself, but personally i feel the car is sitting too high and it looks like there is too much gap. if i went with 255/40s, i would most likely be forced to look into lowering my car, which i do not want to do at the moment.
it would be nice to see a comparison photo side by side of a 245/45 and a 255/40 on stock wheels and springs.
but anyways, thank you all of you guys for your input and pics. i read thru the entire thing and i feel as though i'll know what i'm talking about when i go to the dealer or discount tire to purchase new set of tires.
Originally Posted by FADE
When I bought my tires I didnt know the 255 would fit. Oh well.
Here is a pic of my 245's
Old 03-20-2007, 10:27 PM
  #219
Inaccurate's Avatar
Good find !!!!!!! THANKS
This should add some clout to this mod
Old 03-23-2007, 12:44 AM
  #220
One on the right for me
subinf's Avatar
Finally need to throw on some new tires. Will get it done next week and hopefully will have 255s by Friday.
Old 03-31-2007, 02:52 AM
  #221
binTL's Avatar
Who are you guys getting these tires installed by? Asked Costco and they said no. Any recommendations?
Old 04-01-2007, 02:25 AM
  #222
Inaccurate's Avatar
Yep, this has happened to several people in this thread. The problem was resolved by trying another tire shop.
I suppose businesses are so afraid of getting sued that they are afraid to deviate from the oem recommended size.
Another option is to take just the wheels to them, not the whole car. Have one shop to remove the old tires from the rim. Then, take the loose rim and the new tire to another shop to have them mounted. In this way, it will prevent the second shop from knowing that the oem size was 235 because the second shop never had a chance to see the oem size – thus, they will not complain that you are using a non-oem size.
Old 04-02-2007, 11:01 PM
  #223
Ghost Rider
Thumbs up Follow up
Firstly, I didn't have any trouble getting the little repair shop down the road from me to change my tires.
Secondly, I have now put 1500 miles on the new tires, and I have not got a single complaint, I do have a few positive observations.
1. I can't imagine why, but the car feels easier to maneuver at parking lot speeds, maybe it's just the tread pattern.
2. The reported average fuel economy has consistently been between 1 to 1.5mpg higher than with the standard tired.
3. I was kind of worried about aquaplaning with 80 combined millimeters of additional tread around the car, but I had to do an emergency stop in the recent rain and if anything the car felt better planted.
4. The wider tires do look meaner, I took great pleasure in pointing out to my brother-in-law that my sedan had wider tires than his 911 Carerra!
That's it, so far so good, will do this again when these tires are spent.
Old 04-03-2007, 06:44 PM
  #224
6th Gear
ohiodave's Avatar
question... isn't the 2007 type S just a little bit lower already than the regular TL? if so, then wouldn't the 255/40/17 tires on oem wheels reduce the gap as compared to the same tires on a regular TL? or is the type s lower because it already has lower profile tires than the regular tl?
Old 04-03-2007, 09:03 PM
  #225
subinf's Avatar
well, after 2 years of saying i would get a different brand/size tire i wound up putting the same size/brand back on the car. can't mess with what works. maybe next time
Old 04-03-2007, 09:26 PM
  #226
Inaccurate's Avatar
It is Not just you. I mentioned the same observation in my opening post (Post #1).
Did the wider tires make my steering wheel feel heavier ? NO. The steering actually feels a bit lighter. Why ? I don't know why the steering is lighter than it was with the OEM tires. Stiffer sidewalls (from lower sectional profile) perhaps.
Ghost-Rider, Thanks for providing the feedback. Instead of my "Top 10" reasons, we now have Ghost-Rider's "Top 4" reasons !!!
By the way, any chance of getting some pics ? If you like, I can host them. See me a PM and I will send you my email address.
What tire brand/model did you get ?
Old 04-03-2007, 09:35 PM
  #227
Inaccurate's Avatar
subinf,
Thanks for the update. Maybe next time !
It is easy to experiment with different oil and different car wax, but not so easy to experiment with tires because of the cost involved.
Old 04-03-2007, 11:59 PM
  #228
techguy's Avatar
It has been 2 months since I replaced the Turanza with Falken Ziex 255/40-17. I got them at Discount tire. With these set of tires, it feels like I got a new car! The handling is a lot better and feels more stable. The ride is very smooth both with just the driver or fully loaded. Oh, it looks good too :-)
Old 04-04-2007, 10:05 AM
  #229
BEAR-AvHistory's Avatar
Received 2,599 Likes on 1,581 Posts
Is anyone running 255/40/17 YOKOHAMA AVS ES100 ?
Old 04-04-2007, 11:07 PM
  #230
Inaccurate's Avatar
techguy,
Thanks for the reply. It's good to see more TL'ers enjoying this mod.
Old 04-05-2007, 01:11 PM
  #231
untamed's Avatar
I have also done this mod, with falken 452's and the ride is amazing...........
Old 04-05-2007, 05:36 PM
  #232
Frank S's Avatar
Sign me up!!
The winter tires (dunlop SP Winter Sport 3D's - 235,45's) are coming off Saturday morning at 10:00am and the 255/40 F-1's are going on for the summer. I'm looking forward to seeing how these tires look and feel on the car. I'll give an update after they are on and possibly will even take some pictures if I like the way it looks.
I have a 2005 silver TL w/navi, black interior, body kit and rear lip spoiler.
Old 04-05-2007, 08:43 PM
  #233
Inaccurate's Avatar
Damn, I am glad to see this mod finally gaining some "traction".
If anyone would like to have their 255/40 tire pictures posted here in this thread, and you don't have a hosting service (or unsure how to post pics) - - just send me a PM. I will give you my email so that you can email the pics to me. I will get them posted for you.
Old 04-06-2007, 07:19 AM
  #234
b rad's Avatar
just put on some kumho last nite, tireking no questions asked, tirerack just told me to keep 36psi i the tires...
love em,
$104 each for the tire tirerack, $60 for install cant beat it...
thanks all,
Old 04-06-2007, 09:57 AM
  #235
Pankul's Avatar
just a tiny update from me, I got 255/45-17 Kumoho from Tire Rack as well, (about 104 each, $80 install at firestone)
Very happy with them.
If anyone cares for pics for comparisons here let me know. (i needed all seasons and softer ride hence 45)
P
Old 04-06-2007, 11:31 AM
  #236
6th Gear
ohiodave's Avatar
i found the best pricing at tires-easy.com and you can have them delivered directly to a tire center near you. got the hankook ventus sport k104 zr17's, the tread looks similar to the eagle f1 only 86 bucks a tire.
innacurate and others... do you find that a lower psi will make the contact patch more flat?
Old 04-06-2007, 02:34 PM
  #237
binTL's Avatar
Do you guys buy the Road Hazard warranty?
I am thinking 255/45R17 once i am through with the Michelin PS2's. Almost there so I guess i should start shopping. I want something that has a longer tread life now than "on rails" handling.
Old 04-06-2007, 09:11 PM
  #238
Inaccurate's Avatar
ohiodave,
I have experimented extensively with different tire pressures. I assume you are asking about making the rear tires lay more flat. If so, the answer is no. There is no amount of low tire pressure that will force the rear tire to have as much contact as the front tires. For an experiment, I have gone as low as 26 psi in the rear. And, the rear contact patch did not increase at all. There is just not enough weight at the rear of the car (even before my TL Diet) to push the rear tire flat as much as the front tires.
Below is a re-post from earlier in this thread. This is the pressure that I have been using for the past 5 months.
For anyone that buys 255/40's, here is the tire pressure that I recommend .
Front
33 "cold"
35-36 optimum (as seen on MID while driving after tires have warmed-up)
Rear
30 "cold"
31-32 optimum (as seen on MID while driving after tires have warmed-up)
This is the ideal tire pressure for my Goodyear Eagle F1's. I would speculate that other brands of 255/40's would prefer these settings too.
I have been experimenting with various tire pressures. My testing consisted of NO SLALOMS and NO SKIDPADS , sorry. It did consist of trying different pressures each day along my daily commute to/from work. I judged the pressure by how easy the car seemed to roll (mpg concerns), how much the steering felt like it was driving on rails, and (mainly) how much the rearend wiggled when jiggling steering wheel at 60-80 mph.
So, after trying different pressures, I found the above setting to give me everything that I was looking for - car rolls very easy with great mpg, EXCELLENT STEERING LIKE RAILS, very stable steering, and NO rearend wiggle.
As a side note - the rear pressure is very sensitive.
1) If the rears have much less than 30 psi (as seen on MID while driving after tires have warmed-up), the car rolls sluggish (hardly detectable, just my feeling), the steering has less "driving on rails" feeling, and there is mild rearend wiggle when jiggling steering wheel at 60-80 mph.
2) If the rears have much more than 33 psi (as seen on MID while driving after tires have warmed-up), the rearend will wiggle when jiggling steering wheel at 60-80 mph. And for reference, this wiggle is NOT dangerous. The wiggle is the same as the oem tires would exhibit.
Old 04-08-2007, 11:15 AM
  #239
Frank S's Avatar
I had the F-1's installed yesterday!! I have to say the car feels much more stable and as Inaccurate says feels like it is riding on rails. It makes the car feel like a much greater quality car. Well I'm off to visit the family.
Thanks again Inaccurate and everyone else for sharing all of the information in this post.
Old 04-26-2007, 04:18 PM
  #240
NJ Vike's Avatar
Wheels and Tires
Greetings! I have a 2007 Acura TL Type S and want to replace those stock wheels with something a little nicer. Perhaps in chrome. So far, it has been hell trying to find out if any wheels fit other than Ron Johns. My question is that if I do find a nice wheel, will going to a 19" tire & wheel combo take away gas mileage? What about speed performance like 0-60 or 1/4 mile? Will I need to have my Speedometer recalibrated? I have 235-45-17 and would like to upgrade to a 235-35-19.
Thanks in advance.
Quick Reply: Why you should get 255/40-17 tires for your OEM rims !!!
