Wheels and tires for '08 TL base model
Old 10-23-2014 | 09:45 AM
Oscar E's Avatar
9th Gear
hey guys I need a little help, im new to this site , I am trying to buy new wheels and tires for my 08 TL base model all stock, I was looking at Niche Milan, would these fit? do I have to do any modifications to my car /fenders, which of those to sets do yall recommend? and not lowering the vehicle.
Size: Front 20x8.5 Rear 20x10
Bolt Pattern: 5x114.3
Offset: F +35 R +40
Hub-Bore 73.1mm
or
Size - Front: 19 x 8.5 / Rear: 19 x 9.5
Bolt Pattern - 5 x 114.3 ( 5 x 4.50 )
Offset - Front: +35mm / Rear: +40mm
Hub-bore 73.1mm
thank you
Old 10-23-2014 | 09:49 AM
why do you wanna run staggered?
the 19's will fit with no problem at all.
the 20s will most likely need a pull/roll of fender in the rear.
Oscar E (10-23-2014)
Old 10-23-2014 | 10:11 AM
Oscar E's Avatar
9th Gear
I just like the wave the concave looks on these wheels, I guess I can go with the 19's to be on the safe side Thanks Justnspace.
Old 10-23-2014 | 10:18 AM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
Going staggered means you can't rotate your tires and the TL is a FWD car and you would have the larger tires on the rear axle.
justnspace (10-23-2014)
Old 10-23-2014 | 10:27 AM
I just think it looks silly to have the rear very aggressive and on point, but then the fronts are super weak.
20x8.5 is super weak.
20x10 is pretty aggressive.
in addition to not being able to rotate tires; it just seems like a lot of money wasted for less than ideal specs
Old 10-23-2014 | 11:26 AM
Oscar E's Avatar
9th Gear
you know I didn't think about the rotating, so what do you recommend on 19's 19x8.5 or 19x9 ?
Old 10-23-2014 | 11:35 AM
NBP04TL4ME's Avatar
You aren't the only one who forgets about rotation when they get hot and bothered about getting new rims and tires
Width of the rim will somewhat depend on the design of the rim inclusive of the offset. Find something you like and/or then look at some of the threads here on AZ and do some research both here and on the interwebs.
Tons of combinations and set ups to be had...................
Old 10-24-2014 | 07:37 AM
I like my rims more aggressive.
I dont know about you......
the stock rims are 8 inches wide.
if you move to the 19x8.5, you're not upgrading that much.
if you move to a 9 inch wheel; it'll look better and more aggressive depending on offset.
i am running 18x9.5 +22 all around.
Are we whoring out our cars?
96SC4 (10-24-2014)
Old 10-24-2014 | 08:16 PM
Steven Bell's Avatar
Oscar, if you want to run staggered, you might want to consider 18's and 19's.
Old 10-25-2014 | 02:09 PM
you shouldnt run two different sized wheels; that's dangerous!
Old 10-25-2014 | 03:32 PM
NBP04TL4ME's Avatar
Steven how does running different diameter rims make it staggered?
booma1218
05-03-2016 07:39 AM
Quick Reply: Wheels and tires for '08 TL base model
