Wheels not fitting
Old Dec 12, 2014 | 06:51 AM
pmgruba's Avatar
6th Gear
Wheels not fitting
Hey guys, I need some quick advice. I have an 05 TL MT and it has the Brembo front calipers. I am aware that I need the 17" x 8" wheels (factory stock) in this case in order to fit over my calipers.
I had the Type-S wheels on there and they worked just fine but were stolen two weeks ago I didn't have money for new Type-S so I bought factory 5 spokes 17" x 8" 5 x 114.3, the mechanic says that they are rubbing the caliper. I have no idea why and no idea what to do! Are the Type-S wheels larger than 8" do they have more room carved out in order to accommodate the Brembo caliper?
Please help!
Old Dec 12, 2014 | 07:52 AM
the factory 5 spokes from an 04-06 TL WILL Clear brembo calipers.
the 6MT 04-06 TL's came with brembos.
my stock wheels clear my 06 6mt TL with brembos.
if you happened to get the 07-08 base rims, they clear, but barely.
Old Dec 12, 2014 | 08:29 AM
pmgruba's Avatar
6th Gear
Thanks for the reply, man. Ya that's what I figured, I really have no idea what the shop is talking about, what sucks even more is the fact that I should be doing this on my own like any other repair but I'm so swamped with work I had my buddy's shop handle it...regretting it already.
Old Dec 12, 2014 | 08:33 AM
which ones did you get the 04-06's?
Old Dec 12, 2014 | 09:49 AM
pmgruba's Avatar
6th Gear
Yea, I met a guy at the local Acura dealer and we was able to hook them up at the dealer rate of $550 for the set out the door. What do you think?
Old Dec 12, 2014 | 11:08 AM
I think they'll fit no problem.
about the price; i have no say.
Old Dec 12, 2014 | 04:57 PM
LogicWavelength's Avatar
you can also buy a 3mm spacer for a few dollars. This will clear the caliper and won't noticably impact stance/appearance/rubbing issues or anything.
Amazon.com: (2) 3mm 5x114.3 Hubcentric Wheel Spacers for Acura TSX TL Honda Accord Civic Prelude CRZ (64.1 bore): Automotive Amazon.com: (2) 3mm 5x114.3 Hubcentric Wheel Spacers for Acura TSX TL Honda Accord Civic Prelude CRZ (64.1 bore): Automotive
Old Dec 17, 2014 | 03:55 PM
ExcelerateRep's Avatar
Former Sponsor
If you do end up needing wheel spacers we have the H&R TRAK Spacers available on our website.
They are available in various thicknesses, here is a link to the 5mm which would probably do the trick:
H&R TRAK Spacers & Adapters - Excelerate Performance - Japanese and European Performance Specialists!!
Old Dec 17, 2014 | 03:59 PM
d1sturb3d119's Avatar
H&R are awesome spacers and TUV approved. I got 25mm spacers and stockies for the winter setup! Look online you might find OEM's for cheap. I picked up a second set for 180 with winter tires.
Feb 25, 2020 09:57 AM
nanos
Nov 12, 2015 08:41 PM
braveheart
Sep 7, 2015 08:12 AM
Hau_nguyen91
Sep 6, 2015 12:53 PM
bailey24
Aug 31, 2015 05:38 PM
