wheel spacers
Old Sep 4, 2010 | 02:47 PM
1qwik6's Avatar
wheel spacers
i am getting new wheels in a few months but in the mean time i was at the shop talking to a guy who mention wheel spacers, as a temporary fix to my wheels being tucked in. they look like gaskets made of metal essentially. i would like my factory wheels a little more flush with the fenders. does anyone have an experience with using this? would be be safe or mess up the car in anyway. the main reason i am looking at this idea is they are only 12 bucks a piece and thats alot cheaper than buying wheels right now
Old Sep 4, 2010 | 03:18 PM
LostSol's Avatar
Chapter Leader (Central Florida)
Many people have used spacers to great effect with stock wheels. If your going to do more than 3 or 5 mm, get a bolt on spacer like the Ichiba V2, they come with new studs pressed in so your not running your lugs on 2 threads
Old Sep 8, 2010 | 12:42 PM
1qwik6's Avatar
ok so i guess i am in the market for some hub centric spacers, 20 mm for the front and 25 mm for the rear. i belive that will give me the desired look. i have seen he ibach ones on there website for 135 a pair, are there any other brands out there that are any good. where has the best prices on spacers
Old Sep 8, 2010 | 01:08 PM
myron's Avatar
those are pretty much the best prices. 200-250 for 2 pairs.
Old Sep 8, 2010 | 01:32 PM
TJD2007TLS's Avatar
I'm running 3mm spacers on a '07TLS and there is no need for a wheel stud change but I was told that if I went to 5mm spacers you need to change the studs.
Maybe this helps?
Old Sep 8, 2010 | 10:17 PM
odishaw's Avatar
project kics spacers are a graet product aswell. just so you have some options. they are spacers with new studs
Old Sep 8, 2010 | 10:26 PM
AMUA6's Avatar
ScoobyZINE
5MM being the MAX without longer studs.. keeping it below 5MM you should be fine. Better make sure 5MM is what you want and will be enough though
Old Sep 9, 2010 | 06:51 AM
1qwik6's Avatar
I am looking for 20 and 25 mm spacers. Ichiba does not have the 20mm in stock, where is a good place to order from
Old Sep 9, 2010 | 07:57 AM
LostSol's Avatar
try http://shop.tougefactory.com/
james357
Feb 13, 2016 02:37 PM
obert
Nov 14, 2015 09:59 PM
yvr_tsx
Sep 15, 2015 01:14 PM
jmoney2001
Sep 11, 2015 12:07 PM
mtl_ilx
Sep 3, 2015 09:48 AM
