wheel locks - what brand?
I'm looking for a set of wheel locks for my TL and I've found a set of Kyokugen lugs that's suppose to be lighter and it has a special socket to remove them, but all I've found so far are the open end ones. Does anyone have any suggestions? I know Volk Racing or Rays Engineering has simular lugs, but it's around $130 for a set......ouch.
Sorry to intervene here, but did anyone see the gator grip ad, it's basically a wrench that can lock to any kind of shape. I wonder won't that make wheel locks obselete ??
P.S : I use McGard wheel locks though, it's pretty well known and recommended by a TLer TLDaddy
EDIT : To be exact , it's the splinedrive lug nuts plus one wheel lock, 4 special shape lug nuts and 1 wheel lock for each wheel. check out www.mcgard.com for details.
![Cheers](https://acurazine.com/forums/images/smilies/cheers.gif)
yes a gator grip will hold onto any nut but only in a space where the damm socket can fit ...i presonally like the spline drive lugs but someone told me those wheel places have a special kit that supplies em with every key available for emergency's when u loose ur key and need to get the lugs off.
Moderator Alumnus
Originally posted by BostonTL
Including the wheel lock ?? or just the splinedrives ?
![Arrow](https://acurazine.com/forums/images/icons/icon2.gif)
Originally posted by valuetl
Us these gorilla locks. All nuts are locks and they look like regular lugs. Sell for around $60
Will these fit on aftermarket wheels?
you never said what kind of wheels you have? if you have stock wheels, you need lugnuts and locks with a radius aka domed tip. if you have aftermarket wheels, you will more than likely need acorn aka tapered tips. then the other concern is the diameter of the key socket...it must fit within the openings on the wheel (slightly smaller is preferable so you don't scratch the wheel). one last thing is the type of lug...open ended or closed ended.
![Mad](https://acurazine.com/forums/images/smilies/mad.gif)
![No No](https://acurazine.com/forums/images/smilies/nono.gif)
6G TLX-S
Originally posted by Lawaia
I know for a fact that Gorilla ain't got such a kit....my friend lost his key and the code for his locks. Mercedez somehow got one of his lugs off and had it sent to Gorilla so they could find the right key. Now maybe for those foreign made cheaps...anythings possible.
Moderator Alumnus
that was Mercedes...... not a wheel n tire shop !!!
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
Gorilla locks will fit your ride. If you still have stock rims they will have to most likely order them for you.
All you need to get is a nut splitter to get your lock nuts off if you loose your key and key code. I have seen it done many time at Discount Tire.
tman570
06-11-2019 07:56 AM
ahsm
09-09-2015 08:35 AM
braveheart
09-07-2015 08:12 AM
