Wheel HELP
Old May 16, 2017 | 11:54 AM
dyang17's Avatar
Wheel HELP
Hi all,
I am trying to figure out if these wheels will fit my 05 TL. Enkei NT03 +m 18x9.5 et40 5x114.3 wrapped with 255/35r18. I do have Tein SA coils. Will I rub or need to do anything special?? Please help.
Thanks all!
Old May 16, 2017 | 12:24 PM
it's all dependent on your height. if you are too low, then yes you will rub. which then you can play with the variables...
- raise car
- roll fenders
- play with camber
or a combination of the three
Old May 16, 2017 | 12:55 PM
ExcelerateRep's Avatar
Former Sponsor
If the OEM wheels are the 17" 5 spokes then the new wheel/tire setup will sit 19.1mm closer to the suspension strut, and poke out 19.1mm more then before. So, if you don't have room for that extra 3/4" of poke (19mm) then you'll need one of the things Justin said.
We have camber kits, we can get you those rims, and we do tires too! When you decide you're ready to order feel free to send me a PM or email me directly at performance@excelerateperformance.com and I'll see what we can do for you!
Good luck & happy modding!
http://hoa.excelerateperformance.com/
Old May 16, 2017 | 01:58 PM
dyang17's Avatar
What happens if I get different set of tires? Would that change?
Old May 16, 2017 | 02:04 PM
tires is apart of the variables. so yes. if the current set up rubs...
- raise car
- play with camber
- play with fenders
- play with tires.
it's a lot of work, slapping on wheels isnt just slapping on wheels. if something doesnt work, you need to put in the work to correct it.
there are MANY MANY DIFFERENT ways to skin a cat...
Old May 16, 2017 | 02:12 PM
dyang17's Avatar
What would be recommended tire size you recommend Justin?
Old May 16, 2017 | 02:34 PM
i like my tires fat because racecar.
I just recently put on 265/40/18s on my 18x9.5 +22. so sexy. so much race car.
i had to raise my car. i had to pull and roll fenders. and i need a camber kit to correct camber.
it's a lot of work, my friend!
aggressive in the type of rubber compound and how fat they are.
i picked up some Nitto Invo's recently...265/40/18s
this is the way I enjoy my car. fat race car tires that grab traction
Old May 16, 2017 | 06:18 PM
VisualEchos's Avatar
Andrew
Originally Posted by dyang17
Hi all,
Thanks all!
No, you won't rub, period. That combo is perfect. However, there will be a tiny bit more wheel gap than you are used to because the tire is about .5" shorter than stock, so you'll have about .25" more wheel gap, meaning you will need to drop a bit more.
Old May 16, 2017 | 06:19 PM
Andrew
18x9.5 +40 with 255/40 tires, no rubbing whatsoever.
Perfect. (Explore)
by Andrew Thompson, on Flickr
