What do I do first? Change tires or alignment
I need to get new tires and I need to get my 4-wheel alignment done. I can not get them done at the same place. What do I do first? Alignment then new tires?
I would think the tires first as they must be balanced and then the alignment. But you can post this question here in TIRES/WHEELS/SUSPENSION for clarification:
https://acurazine.com/forums/forumdisplay.php?f=97
Doesn't matter which one you do first, as long as you do them both on the same day. The only exception would be if you have severe uneven tire wear, which can cause the wheel to lean - giving you improper alignment readings. If this is the case, replace the tires, then drive to the other shop where you can get the alignment done.
The Darker the berry....
Change your tires, then do the alignment right after - any mechanic worth anything will tell you this. Think about it - your tires are what sit on the pressure plates on the alignment machines. If your tires are all screwed up with popped radials and uneven wear, then what good are the calculations? If your tires are OK, then it's good to do an alignment every once in a while, but if a tire replacement is coming anywhere in the near future, then do the alignment with the new tires.
Registered Member
You're spot on.
As the tires move very easily on the alignment turnplates, the calculations are based on the suspension geometry from wheel clamps that are affixed to the wheels. The correct alignment has nothing to do with bald, feathered, or an irregular tread. If that were the case, everybody would need to buy new tires when getting an alignment to ensure that the tread is perfect.
Not much of a mechanic are you! Got to add either of you!
Not gonna argue the point (too much) cuz I think it really is common-sense. But, if you go to an alignment shop and ask, most will tell you that if your tires are IN NEED OF REPLACEMENT, i.e. heavily worn, damaged radials, uneven tread, etc., they will recommend you replace the tires before you do the alignment because it DOES affect the calculations. Ever notice that one of the first things an alignment tech will do when they get your car on the machine is to check and adjust your tire pressure? Why do that if tires don't matter? The main calculations are taken by the wheel clamps but the condition of your tires does matter. Read my previous post - I never said you need new tires to get a proper alignment.
The reason they look at the tires and if worn considerably, cupped, feathered, camber wear etc. they normally recommend new tires before the alignment...WHY? Not because they can't do an alignment, but if the tires aren't replaced and the alignment is done, the vehicle will handle poorly as the tread to road contact surface has now changed. You might feel it in the ride or handling, but the alignment will be correct, but try expaning it to your customer. TRUST ME......... I'm done.
Zonian22
11-14-2015 01:20 PM
Zonian22
09-02-2015 08:19 AM
