Weird noise from front right tire/wheel...Anyone?
Old Feb 2, 2012 | 07:03 AM
Mdumanski01's Avatar
I got my tl used and it's in pretty perfect condition. Yesterday was 63 degrees in PA and was the first time I drove with the windows down, and I noticed a noise from the front passenger tire area. It sounds like the tire has something "sticky" on it, and every time it goes around you hear it "unsticking". You can really notice it going very slow, once you go faster it is still there but not as noticeable. I had my car for a month and a half and yesterday was the first time I noticed it...cuz the pass window was down.
I have TOYO proxis, and they have at least 90% tread left.. Everything was balanced and aligned dec 15th...
I'm not too worried about it now, but in the summer I drive with the windows down and it's too annoying, plus I don't even know if u can hear it from outside the car..
ANY IDEAS??
Old Feb 2, 2012 | 07:16 AM
truonghthe's Avatar
^^^^ rock stuck between tire track? that is that is the only thing I can think of.
ABP_04TL's Avatar
6-SPEED LOVER
Check that tire out maybe u have a nail in it... But then again ur saying its a sticky sound? Hmmm. Only thing i can possibly think about its a nail, remove the tire and take a look.
Btw drive with ur windows up and a/c on durin summer saves u more gas
Old Feb 2, 2012 | 07:48 AM
Nail maybe but then again I don't think I would be able to hear it at a roll... Like I mean, u can hear it from the drivers seat going 1mph, and it has the same loudness as going 5mph.
Old Feb 2, 2012 | 08:25 AM
**WhItE-aNgEl**'s Avatar
I have that same noise sometimes. I always thought it was the tpms sensor inside the tire. It's like a sticky but mine goes away and comes back rarely.
Old Feb 2, 2012 | 08:51 AM
Jesstzn's Avatar
Looked but can't find the thread.... there was an issue with a shield over part of the drive train that will make a noise ... mine did untill I adjusted it .. maybe someone else can find it .
cpm06wdptl's Avatar
Check your tire pressure. Either that or maybe the tire is either out of balance or could possibly be flatspotted. Has it been sitting for a while without being driven?
Old Feb 2, 2012 | 09:29 AM
Project_CLean's Avatar
MMkay.
^ that? or check your tire pressure and look over the tire to see if anything is on it.
Jesstzn: was this the link you were talking about: https://acurazine.com/forums/3g-tl-problems-fixes-114/rattling-drive-shaft-heat-shield-839129/
Old Feb 2, 2012 | 11:12 AM
I wouldnt think it would be flat spotted, the tires are pretty new and I bought it off the lot the first day they had it for sale. The little rubber things haven't even worn off the tires yet.
Old Feb 2, 2012 | 01:11 PM
flyromeo3's Avatar
I actually encountered this problem and posted pic's too.
Can't find the thread though. Think it was 1.5-2 yrs ago.
basically the bolt holding the heatshield is loose.
This bolt sits right above where the two exhaust pipes meet. There is a gap in between them where you can use a long ratchet 3/8 and tighten it up.
Old Jul 19, 2014 | 08:26 AM
3BYSN1QT's Avatar
9th Gear
same issue with my ZDX
ANY IDEAS??
Hi. I am having the same issue with my ZDX, just want to know what happen to your vehicle that causes this problem.
Old Jun 24, 2015 | 10:11 PM
robowarrio's Avatar
Tycoon
Anyone have this issue? I have this issue as of right now..
Old Jul 13, 2015 | 04:39 PM
Sorrac's Avatar
Sticky sounding tires
Ok, I have the sticky issue with my rim/ tires. I have KMC 22" rims with low profile 305/40/22.Mine started making noise last week after a car wash detailing. My only thought is they got too much armourall on the tire/rim seal and it's making a wet rubber on alumn. Sound. Any thoughts or experiences on this?
Old May 15, 2018 | 08:49 PM
josh macdonald's Avatar
Inside wheel coating
I had the same issue with mine, it was the interior of the wheels coating coming off peeling like an orange, rubbing against my brake caliper. everytime the wheel turned it was hitting my brake caliper ,scraped it off and noise was gone
Feb 25, 2020 09:57 AM
marcelft
Jul 10, 2018 06:17 PM
DwDrummer
5G TLX Problems & Fixes
Sep 14, 2015 08:20 PM
Steven Vitek
ILX
Sep 10, 2015 07:29 AM
08 NBP TL
Sep 8, 2015 08:49 PM
