Want to upgrade your Comptech RSB Sway Bar? Use better bushings w/grease fittings...
Want more performance out of your Comptech RSB, less squeaks/rattles/thumps, and the ability to grease them while mounted on the car regularly? Check out this thread, Energy Suspension products makes a far superior product to the ones Comptech sends out with the RSB and it's only $15!
http://www.energysuspension.com/pages/prodbene.html
You can also upgrade the end links for like $15, I read someone on the boards said their's was bent.
https://acurazine.com/forums/showthr...=comptech+sway
I listed the part #s for the TL CT RSB you would use there as well.
http://www.energysuspension.com/pages/swaybbct.html
P/N # 9-5158 if you want the greaseable ones.
so are you using this or are you just advertising it
and is there some universal part or something that we can use on the tl because if im not mistaken they dont make any products for tl's (http://www.energysuspension.com/pages/acura.html)
Yes, well I will be, I just ordered it last night it looked good. You could replace a bunch of components that are better/stiffer in the suspension with their parts actually if you wanted to.
I just put in my CT RSB this afternoon, and will change to these bushings when they show up in a few days, I will take pics for you all.
As far as a part #, yes they don't list our TL, you just use the universal for our car for a 22mm RSB. I listed the part # (part #9-5158) I ordered if you want the ones you can grease, they are found on the vendor's website under universal though, yes.
Chief
What about the part # for the un-greased ones??? Do you have a part # for those as well??? Thanks.
Sure thing, although I'm starting to sound like a company spokesman or something and I'm not! lol Just looked like a cool upgrade / product I could share with everyone as I found it buried in a post somewhere on here....
Performance Sway Bar Bushing Sets-Non-Greaseable Type
Sway Bar Diameter "A" - 7/8" / 22mm - Non-Greaseable Set # - Part # 9.5108
Color Code for sway bar bushing sets, add: G- black, R- red.
Example- #9.5151R = red The greasable ones I ordered only come in red.
Now what I want to know, is what is the correct size / part #s for the End Links and are these easily swapped out too I wonder, this company has a whole line of similar performance products that could be used, pretty inexpensive too if you can put them in yourself. The end links are the pieces that connect to the ends of the rear sway bar, correct? (I'm not much of a mechanic so the parts/terms kind of throw me sometimes still, unless we're talking boats!)
http://www.energysuspension.com/pages/endl.html
I will take some good pics of the whole installation process for these when they arrive, now that I did the CT RSB yesterday it will be easy to do it again and swap these out. With tire ramps and the right tools the whole thing was super fast and easy.
For the maximum performance benefit from the products shown on this page, use these sway bar bushings with the performance polyurethane sway bar End Link items found on the End Link page: Now what I want to know, is what is the correct size / part #s for the End Links and are these easily swapped out too I wonder, this company has a whole line of similar performance products that could be used, pretty inexpensive too if you can put them in yourself. The end links are the pieces that connect to the ends of the rear sway bar, correct? (I'm not much of a mechanic so the parts/terms kind of throw me sometimes still, unless we're talking boats!)
if spending 20 bucks or so gets that annoying thud out of my rear end, thank god. if not, then i'm only out 20 bucks.
i will also give some feedback when i get them on. i ordered them today
Chief
Originally Posted by TL-CrAzIe-05
Where did you order them from??? Thanks
Get better handling.
These Hyper-Flex polyurethane sway bar bushings offer great improvement to your steering performance. They make your vehicle's sway bar system much more effective--almost like adding a larger, higher performance sway bar! Economy, increased efficiency, and easy installation are just some of the reasons they are so popular. They come with heavy gauge brackets that feature a gold cadmium finish for long lasting good looks and strength.
Here's their part # for the one that fits the Comptech RSB.
http://store.summitracing.com/defaul...p&N=115+400008
ENS-9-5158R
$13.95
Estimated Ship Date: Monday
Application Show All
Brand:Energy SuspensionProduct Line:Energy Suspension Sway Bar BushingsFrame Bushings Included:YesFrame Bushings Greasable:YesSway Bar Diameter (in):7/8 in.Sway Bar Diameter (mm):22mmEnd Links Included:NoBushing Material:PolyurethaneBushing Color:RedMounting Bracket to Sway Bar Centerline Height:3/4 in.Overall Sway Bar Bracket Height:2 1/4 in.Sway Bar Bracket Maximum Bolt Center to Center:3 5/8 in.Sway Bar Bracket Minimum Bolt Center to Center:2 9/16 in.Quantity:Sold as a pair.Notes:Not recommended for fullsize pickups.Bushings, Front/Rear Sway Bar, Greaseable, 7/8 in./22mm, Red, Universal, Pair
ENS-9-5158R
$13.95
![](http://store.summitracing.com/global/images/1105/r_dt_left.gif)
![](http://store.summitracing.com/global/images/1105/r_dt_overview.gif)
![](http://store.summitracing.com/global/images/1105/r_dt_right.gif)
click on the summitracing link and paste that part # in their search
this was from another thread
See Post #44
Mine arrived today, I can tell right off the bat the brackets are a lot stronger, and the material seems a whole lot stiffer, it's hard to even open up the gap in the rubber (poly actually on these) part of the bushing.
The grease gasket looks cool too, and there are little channels grooved out inside the bushing so that the grease can get in. I would imagine it's a good idea as well since water might get in there over time, new grease pushes it out, just like we do on the sailboat's underwater prop with grease fittings in the fall so it doesn't freeze over the winter...
I willl take a bunch of pics and load them up this weekend when I install these, it will be basically the same as doing a rear sway bar installation, which having done once, and having the right tools, is VERY easy.
Pics Pre-Installation
Summit threw in some stickers, a hat, and a catalog for "Free"
The set themselves
Summit Racing bushing on the left vs. OEM bushing on the right
Same setup. You can see the grooves gqchicago was talking about in the Summit bushing
Another shot with the bracket in it.
![](http://img99.imageshack.us/img99/6718/dsc008017pf.jpg)
The set themselves
![](http://img99.imageshack.us/img99/1426/dsc008036hy.jpg)
![](http://img99.imageshack.us/img99/7457/dsc008056cc.jpg)
![](http://img136.imageshack.us/img136/907/dsc008065ep.jpg)
![](http://img99.imageshack.us/img99/6590/dsc008072me.jpg)
these pics are only for comparison. i cannot compare them to the comptech bushings yet because they are still on the car. figured i'd add that in since somebody would probably ask
didn't get to the edit button fast enough
Team Anthracite Member
Hi guys,
Forgive my ignorance... I just bought these too... How would grease them? Just rub grease inside so it gets trapped in the grooves? Any special kind of grease to use?
I should be installing my Tein SS and RSB and these in the next couple weeks. Thanks.
Originally Posted by zax123
Hi guys,
you can pre-grease them as the instructions say. yes, just rub some in the grooves, then you can hook a grease gun to the connection after they are installed and grease them that way. i just picked up some regular grease from auto zone last night, and am using that.
Hold Up!
****before everyone orders a pair of these****
I just tried to install these, and the bracket is just a tad to big to thread in the second bolt. Also, even if you got the second bolt threaded, there would be no way to fit the socket onto the bolts to tighten them both down. Furthermore, the washer they send along with the kit is a must, as the OEM bolt will not sit flush on the mounting bracket without it.
this is my experience with these over the past hour, maybe gqchicago will have better luck.![Wish](https://acurazine.com/forums/images/smilies/wish.gif)
this is a real bummer. the quality of these bushings over the comptech bushings is night and day. i might actually try to modify the bracket a tad to see if i can get it to work(maybe).
so this is what i have now
Sway Bar Bracket Minimum Bolt Center to Center: 2 9/16 in. This is the problem I am running into, where the bracket is just a little too long for threading the bolts in. Basically, I am just under the minimum so they won't fit.
http://store.summitracing.com/defaul...3&autoview=sku
i am wondering if these would work(need the experts here)
Sway Bar Bracket Minimum Bolt Center to Center: 2 1/16 in. By the way I am reading this bracket, it should fit with ease. It is 2 1/16 vs. 2 9/16 minimums. If I needed to be just under that 2 9/16 measurement, these should work. Although they aren't the greasable ones.
Here are some visual specs of those two bushings
yikes, what a nightmare
I remember reading about this on the TSX forum. The bracket with the grease fitting was slightly too big.
https://acurazine.com/forums/showthr...1&page=2&pp=25
The bracket without the grease fitting, part # 95126, is what they recommended.
thanks jeffa, i think i'm going to try and do what moda did with his bushings brackets. If that doesn't work, I'll order the other ones.
Hey, just so you know, I've got about 15k miles on my modified ones and they are still great!! A little bit of modding to the brackets and a little to the washers (to look more like a D ) all is good.
Good luck and let me know if you need any other suggestions.
Hey Blue Eyes,
I cancelled my order with Summit... do you think I should re-order with the non-greasable? I can't find what exactly moda did to modify his greaseable ones... what would you recommend? Is there really a point in upgrading to non-greaseable from the Comptech ones?
I don't think the bracket is actually smaller. I think the slots are made bigger so the bolt can slide in towards the center. And the washer under between the bolt and the slot is shaved to look like a D instead of an O. I guess it could work, but I don't know how much too small the greaseable bushings are. I'll wait to hear from Blue Eyes before ordering from summit...
Hey Blue Eyes,
from the measurements on summit, energy suspension, and guys from the TSX forum the NON-greasable ones should fit no problem. I definately feel these bushings are leaps and bounds greater than the comptech ones.
guys, you can check it out here what moda did, as well as the NON-greasable bushings
Blue Eyes,
Would you happen to have the measurement of the spacing of the stock bolts?
no, i don't know the measurement for the stock bolts. but, this bracket was a tad to long on each end near the center to meet the minimum 2 9/16 installation. had the bracket been a little shorter, it would have worked. I am going to head to the hardware store to pickup a drill bit to mod this thing.
this pic is after modification by moda. by the looks of it the washer is now this shape - D
if you look where he has the bolts installed, before there was a little more bracket there that had to be shaved down to be able to fit both bolts in. this was also the reason for shaving the washers, as the full washer would not have been able to sit up against the bracket like that.
*on a side note, there is no difference between the black or red bushing for anyone who is just joining us
![](http://img103.imageshack.us/img103/8481/389638131full1zj.jpg)
yes, he said it was very easy ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
I do the TL key mod for folks, so I also used one of my mini-grinding wheels to make the D shape in the washer. I put it in my table vice so that the part of the washer I wanted to grind was sticking up. Ground down the washer and repeated 3x more. Very very simple.
Yeah, your mod definitely looks simple, I'm just wondering if we are also only 1/4" away from the mark. If so, I'm willing to do the mod to the bracket and the washers with my dremel.
:surrender well, i gave it a go, but it just didn't work out for me.
i shaved down the bracket and washer as much as possible, and was able to thread both bolts, but i couldn't get the second bolt tight enough. i couldn't fit the socket in between the bracket and the nut after a certain point. I tried squeezing the bracket also, no luck.
lesson learned, i'll get the other ones.
thanks moda for your help.
Chief
So what part # are you going to order now??? I ordered part #9.5108R. Is this the right one??? Thanks.
you will have the same fit issues i had with the 9-5158R. check the product specs, the minimum sway bar bracket minimum bolt center to center is 2 9/16. we need to be under that.
i ordered this one
hopefully it works
