Want a tight, sport suspension. need info on Eibach Pro-Kit
I have been going through all the forums pertaining to Eibach Pro-Kit... I want to have a tight, sport suspension.... my other car is an evo mr9. i know im not gonna be able to match the awd and overall feel of that car. but when i jump in my 07 tls.. it feels like a boat....
Dubjay (01-22-2013)
Registered Member
Since you want a stiff ride, eibach is probably the springs to go with, BUT they lower the car unevenly. The front WILL sit higher than the rear giving the reverse rake look. Which IMO is ugly. For the stiffest suspension possible, I would look into coilovers and then set the damper on full stiff.
Here is a pic of a member's car (Sharksbreath), that had Eibach springs and stock shocks before switching to coilovers.
Dubjay (01-22-2013)
Chapter Leader (Arkansas)
If you decide to go with the Eibach, let me share a few things from personal experiences:
1) If you start noticing a clinking noise (assuming you have ruled out bad rear struts), you can contact Eibach directly and have them send you some coil "split tubing." Acura also makes these, though they are like $7 each (Eibach sent them free of charge). I added 3 sets of split tubing to the rear of each spring and the noise was immediately gone. Jack up the car, remove tire, and place the tubing as high as you can get it (to avoid coil-on-coil contact).
2) You will probably want to plan on getting a camber kit (particularly for the rear). After lowering (even an inch), camber was pushing -2.5 to -3. Save yourself money and time, and put it on when you do the drop...and the alignment.
While I am also aware of the gap difference between the front and rear, I didn't experience it with my car (see below). As you know, there are a plethora of options for lowering a car - good luck.
Dubjay (01-22-2013)
Thank you Excelerate i will look into that... Cdavis1- how long have you had your eibachs' on b4 the pic. Were they originally a lil higher in front and it eventually lowered to the 'above' hieght... if not, y sag n some cars and some not.. assuming there was no other additions to correct it.
I had pro-kits on my last car and absolutely loved them. Did not have any sag issues at all. I do believe it is different for each car and model of spring they make...as well as luck of the draw.
Standard front with A-Spec. Could just be the lighting.
I don't know what you mean by "feel the road," but I'm happy with my set-up. With that said, you probably won't find too many on here who would recommend springs over coilovers. If cost is an issue, which I and most here understand, go with springs. As has already been noted and as you've probably found on the forums, you have a few options: Eibach, H&R, and Teins. Each has good/bad...and it all depends on your set-up (camber kits, rims, wheels, rolled fenders, spacers, offsets, etc.).
i'm in the same boat looking thinking about doing the eibach as well bc i didn't too much of a drop since it's the gf's car. But the rear sitting lower looks weird to me. maybe H&R sport is a better option for a more even drop.
Registered Member
Coilovers might be a better option for you. That way you aren't stuck with a drop you may not like or a ride characteristic you may not want. With coilovers you can adjust ride height as well as the softness/firmness of them (damper). But it all depends on your budget. Two great coilover brands to look into are the ISC N1 and Tein.
I've got H&R sport springs, seriously nice looking drop plus a great feel. You know that camry commercial where she says "I feel grounded to the ground" lol well the H&R sports do just that. I am actually selling mine, just saying. 516-306-7691 if you want some pictures of my stance with them on the car let me know.
neuronbob
23
07-16-2019 10:48 AM
emailnatec
29
09-28-2018 04:27 PM
