want to drop the ride...
i was thinking i want to drop my car just a little and was looking into the Eibach Pro Kit Excelerate was selling on the group buy section. I was wondering if it would be okay to use those with the stock shocks i have or will it run a risk of blowing them? Would my ride quality dramatically worsen?
I have an 08 Type S
thanks a lot!
I have an 08 Type S
thanks a lot!
Shocks are a wear item. Lowering on OE shocks will increase rate of wear vs OE ride height. In that duration, yes, your car will be fine. But if you look at the cost of good perf. shocks, and springs, your already somewhat near the cost of Tein Basic coilovers for example. Especially if your looking at Koni yellows.
I would say Koni yellows (adjustable perch) and H&R Sports would be a great shock/spring combo as far as ride quality.
I have an 08 Type S
thanks a lot!
I have an 08 Type S
thanks a lot!
The Eibach kit is a mild enough drop @ ~1", that accelerated shock wear is minimal.....a non-issue. In fact, I'd bet that the shocks will last almost as long as if they were paired with the OEM springs. If it were a more radical drop of 2" or more, then I would say that new shocks are a must right off the bat.
BTW...we have coilovers with our OEM set up....they're all coilovers (as in coil spring over shock). Adjustable coilovers are the typical upgrade....only neccessary IMO if you are constantly fiddling with ride height, damping/rebound etc...
Personally, I will probably be purchasing a set of Koni Yellows soon....not because my OEMs are wearing out, but because I want a little bit of adjustability.
Anyways, here's what you can expect your car to look like with the Eibach kit...
I have the same car....with the Eibach Pro-Kit and OEM shocks. It's been almost a year and I've had no issues.....ride is great, cornering is greatly improved, tracks well.
Thanks for setting the record straight. They said the same thing about my other car. I put just springs on (1" drop) and ran the oem shocks. I've got 50k miles on it now and what do you know, the oem shocks aren't worn out yet.
AZ Community Team
Received 7,771 Likes
H&R Sport Springs, OE Shocks.
1 year, 13,500 miles = no problems.
I started with A Spec then went eibach and switched to Tein because Eibach rode like a buckboard, Tein appears to have a similar spring rate to A spec and ride change very similar to A spec
True that man tein s-techs and tokicos ride great
heres some more pics of the drop
https://acurazine.com/forums/3g-tl-tires-wheels-suspension-97/finally-tein-s-techs-installed-710988/
Did the first picture taker turn the wheel cause you're not that happy with the front drop? Reason I ask is because I used to do that with my accord so it wouldn't be as noticeable that there was more gap in front than back.
I would say it depends on your goal. I've gone cheap springs that I even cut on stocks (bouncy and crap), H&R's on stocks wasn't bad...then megan fully adjustable coilovers and now Tein SS. It's the natural progression of things if you have the funds to do it. If not, springs will get the job done. I CAN say that with TEIN's and NO finger gap, a perfect drop IMO, the ride only suffered slightly from the a spec. Not too harsh at all.
My 2 cents.
My 2 cents.
I would say go with coilovers. You will not regret it one bit. Only thing I regret is going with springs before getting my D2 coilovers. If you dont like how low you are, just raise it up, if you dont like how high you are, just lower it. Too stiff? Adjust it and same for being not stiff enough
AZ Community Team
YEAH!! Gratuitous pics of my car.
^ lol...see Bear, eventually ya get to post gratuitous pix of your car...just have to wait long enough!
No actually....that's just the way I happened to park it when I took the pic. I found another pic with the wheels straight.
My car sits with a very slight rake front to back...I love it. I think because the Eibach kit has an even drop all the way 'round and the front wheel openings are slightly larger than the rears, may give an impression that the car "sags" in the rear or that there is a larger gap in the front, especially when parked nose first on an incline....but it's not the case.
More importantly though is the way the car now handles...much better than stock IMO. I've used Eibach kits in the past...always been a big fan. Although I did consider the H&R Sports at one point but the drop is slightly lower and I didn't want my car to be a snowplow in the Winter! But the H&Rs do look good!
emailnatec
29
09-28-2018 04:27 PM
CLOSED: 3G Acura TL Model Car(Blue)
bluetl04
08-16-2016 02:49 PM
us285126
10-02-2015 02:03 PM
4drviper
09-23-2015 07:42 PM
