Type-S Upper Mount (Top Hat) Kit
[Mod Censored Title]
i ordered the type-s upper mount (top hat) kit from heeltoe for my 05 base TL. i needed them for my coilovers so i figured i might as well get the type-s kit with the upgraded rubber bushings. this kit will work on my base TL - correct?
http://www.heeltoeauto.com/Honda-Gen...-pr-63594.html
AZ Community Team
Received 7,770 Likes
http://www.acuraautomotiveparts.org/...s=&view=normal
Check the "Rear Shock Absorber" assembly for rear part numbers.
AZ Community Team
Guys, Im interested in a set of the type s rubber hat bushings.. does anyone have the part numbers for front and rear so I can price them?
Im not being lazy, it's just that I got confused with all the part numbers on the diagram. Not sure which to choose. There are several rubber shock absorber. Thanks!
AZ Community Team
On that site, look up the "Rear Shock Absorber" and then the part in the same position for the rear; Item #20 in the Rear Shock diagram.
Killabee44 (10-05-2011)
AZ Community Team
I believe there is a positive impact, but it's "gravy" to a good suspension, not a main course.
It looks like the front ones are part#: 51631-SEP-A01 for: $15.47
and the rear ones are part #: 51631-SEP-A01 also for: $15.47
There are listed for an 08 TL. I have an 04, will it still be ok?
Each shock absorber takes two of these though. Do you guys know if they sell in pairs? I think they should since you need two per shock.
Not sure though...
One last thing... I should be able to find tophats at a junkyard, no?
Being an Acha Bacha in
Correct. But, imho, it's probably not worth doing unless you're going to have the car mostly torn down anyhow. It's a good bit of work to do for modest improvement. When you're already replacing shocks/springs, etc., is the very best time, imho.
Question: What about those collars in the parts diagram? Aren't they needed too or aren't they different? Also why do we need to replace the rear when the steering feel is mainly in the front? Just curious?
And lastly how much did all 8 run?
AZ Community Team
Thanks for the info...
Yes you need 8 and I don't remember if they sold them as singles or pairs.
I agree. I had to take my TEIN SS and put my stocks back on to get some warranty work done so I figured before throwing the suspension back in I'll upgrade these while they are outside. ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
Collars should be OK. Same part for all TL's '95 -'12.
I only did the fronts in the '02 and it seems fine. If/when I do replace the rear shocks, I'll do them then.
About $125 for all 8.
I am replacing all 4 corners because I bought a whole suspension.
cant let the rears go to waste
this is where I bought them from:
http://www.heeltoeauto.com/product.php?productid=64843
cycdaniel
12-17-2019 10:58 AM
C2CuSn07 TL
09-11-2015 06:54 PM
