TPMS sensor question
Old Dec 22, 2010 | 12:47 PM
speedy4ever's Avatar
can civic or cr-v tpms sensors work on a 3g tl?
can they be programed?
i'm going to run other wheels and didn't want to take the sensors off my stock wheels, i have a spare set of civic and cr-v sensors, just wondering if they work.
thanks
Old Dec 22, 2010 | 03:58 PM
NJ SHAWD's Avatar
Back From The dead
They cannot be programmed AFIK, they work on a specific frequency. You best bet is to check and see if the oem part numbers are the same.
Old Dec 22, 2010 | 08:17 PM
Turbonut's Avatar
I'm certain you'll find that the part numbers aren't the same as the configuration of the wheel makes a difference in the assembly. Actually aftermarket part numbers are different between the 2 vehicles, but that doesn't indicate that they aren't compatible with the receiver. Honda Pilot sensors are the same, so very possible that the sensors will work, but bottom line, I guess it would require a test. Also if the configuration is different, they may be compatible with the receiver, but won't be able to bolt to the wheels without an adapter.
Maybe someone else will be able to give a definitive answer.
Old Dec 22, 2010 | 08:19 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Randy99CL
Apr 7, 2016 06:00 AM
bailey24
Nov 21, 2015 08:43 PM
johnalfa
Oct 31, 2015 12:55 PM
lland
Oct 4, 2015 04:47 PM
datadr
Sep 12, 2015 09:12 PM
