TPMS + Rims H-E-L-P!!!
Alright so i just got a set of rims MRR Gt1's on an 08 TL-S (19'' staggered) and i had them installed yesterday and all was well until.... TPMS message pops up on the nav screen and in the MID.... so i scroll through the MID and click on the TPMS and it says functional error... so i click to check the PSI readings... and at first it displayed 35/58 psi Front Two, and 58/35 psi on the back two... so i brought it back to the tire shop and they adjusted it and says it will take some time but the computer will adjust, so i go back home and stare at my rims all happy and what not- then a few hours later started my 3 hour long journey to school (NJ to RI). On the way, i get message after message on my nav screen giving me like 50 different psi readings... and each time it was different. And now when i check the PSI reading on the MID they are all blank and it says functional error.
Does anyone know how i can fix this? That little exclamation point is annoying as hell and the every time i turn on my car that bright orange TPMS light comes on. Do i have to bring it to the dealer?
94 DC4 RS LSV/Turbo
dont bring it to the dealer with those wheels... most tire shops have signs that read "not responsible for tpms sensors"... my guess is ur sensors are frrrucked up
alright good news... i found out the answer to my question...
i called the tire shop to complain who told me to call teh dealer and i did he said it will take a few minutes to reset the computer.... and it should be good from there so im crossing my fingers and hoping that is true and my sensors arn't broken : /
If you bought an extra set of tpms sensor and install them on your Aftermarket rims, the reading on the display should say 58 to all four tires. and it will read normal later on, but if your nav says that the sensors have problems then it might be the sensors. Then if you bought sensors that is not made for the right car then that can also be a prob. I sure hope someone has the answer to the problem for you but that is what i think
94 DC4 RS LSV/Turbo
just drive it... after a certain amount of miles it will display it
not like on american cars where you have to install the wheels in a certain order
Originally Posted by Tension
I got the same problem but how to reset the tpms?
