Tires sizes for a good stretch
I just bought a new set of wheels, they are 19x8.5 up front and 19x9.5 in the rear. I was wondering what brand if tires stretch the best and what sizes to use in the front and rear.
BANNED
whats the offset?
falken 452
dunlop direzza
just to name a few...
falken 452
dunlop direzza
They are a 40 offset all around and in gonna do spacers in the front and rear. I bought megan coikovers and plan to drop car at least 2 inches all around. I want a really good stretch on both front an rear so I was wondering what size tire to go with?
justnspace (01-31-2013)
snuggles_p_rocks (01-31-2013)
splew (01-31-2013)
BANNED
Sick07Tl (01-31-2013)
Desert Life Sucks!!
I am confused though.
Your title states what size tires are good for stretch.
Then your opening statement says what brands are good for stretch.
What exactly are you looking for. Brands and sizes??
OBX has good tires on the cheap. They come with stickers that will add air ride as well.
i am confused though.
Obx has good tires on the cheap. They come with stickers that will add air ride as well.
The following 2 users liked this post by snuggles_p_rocks:
justnspace (01-31-2013),
sauceja (02-01-2013)
Wow, I didn't realize this fad was still popular.
Then again...
- Impractically low ride height.
- Suspension and alignment changes that wreck the stock geometry.
- Wider rear wheels on a FWD car.
- Narrower than stock tires mounted on rims that are far wider than the ones the tires are designed to properly and safely function on.
Sounds like a great plan.
Then again...
The following 2 users liked this post by splew:
pohljm (01-31-2013)
Thank you for all the help sharksbreath. I really appreciate it. For all the rest of you who did nothing but make jokes and not help.. Your all assholes and not funny at all.. Why are you guys even in the forums if your not here to help anyone out? And I didn't ask which one of you thought I should do the setup I'm doing or not, just needed some help with the tire sizes... It's nice to see that there are some people on here like sharksbreath that are here to help people out when they have questions about there car. Btw shark testy your car looks sick and I hope mine will look as good as yours one day. Thanks again
SharksBreath (01-31-2013)
BANNED
BANNED
Then again...
- Impractically low ride height. SO WHAT?
- Suspension and alignment changes that wreck the stock geometry. MY CAR DRIVES PERFECTLY.
- Wider rear wheels on a FWD car. SO WHAT?
- Narrower than stock tires mounted on rims that are far wider than the ones the tires are designed to properly and safely function on. DEBATABLE.
Then again...
now...those people that run 215/35's on 11" wide wheels...yes, that is insane and i would not condone that.
if you keep it conservative, you'll be just fine. people just like to nay say the idea bc of horror stories they've heard.
On a more serious note, lighten up a bit. Remember, it's the Internet. There will be those who help and others who try to rustle your jimmies. Welcome to Acurazine!
It is unbeknownst to us whether you have any knowledge of these negative effects or not. So us pointing these things out to you might tell you something you didn't know, and possibly prevent you from doing something to your car that you might regret.
People telling you something you didn't want to hear doesn't make them an asshole or a hater either.
A lot of people posts threads on this forum asking about various cosmetic mods that they apparently don't realize are unsafe and/or negatively impact the functionality of various parts of their vehicle. I typically try and provide that person with info/examples of why the mod is a bad idea. If that person still want to do that mod to there car, then that's fine. At least other people who see the thread will be armed with knowledge on the negative effects of said mod.
Do whatever you want with your car. It doesn't effect me, so I don't care. If it makes you happy, that's great. However, I think it is more helpful (not just to you, but the whole forum) to remind you of the considerable negative aspects of what you are doing, rather than just tell you things you want to hear.
BTW, a little time on Google or some math could have found you a good tire size for you application pretty easily.
it's not a fad. it's a way to lower your car dramatically, while running an aggressive wheel setup. there is a ton of bad press about what OP is talking about, but as long as you don't go crazy with the idea...you'll be just fine. i've been running 225/35 tires on a 9.5" +25 wheel for over 2 years and haven't had one single issue...and my car is very low.
I realize there are lots of hellaflush cars out there that are "fine" as of now, but they are still running some rather important components on their cars in ways they were never designed for, which is something worth considering IMO.
Some people are obviously okay with seriously reducing the practicality of their car and undoing suspension and tire engineering that some very smart people put a lot of time and effort into perfecting. That's fine, I'm not bashing it. I just think it's better for people to have the knowledge to make an educated decision on these things.
pohljm (01-31-2013)
BANNED
you should see what happened when I asked for opinions on a wheel and how it might look.......and then all hell broke lose. Like DaeHanMeenGuk said, its the internet, and its just people, for the most part, just bein smart asses. Yes, some is un called for, but I am sure the majority of everybody on here legitimately wants to help when, where and how they can.
HAVE A COKE AND A SMILE!!!!
Sandy Eggo
Then again...
Then again...
O.P...Not sure what mm spacers you will run, But at 2inch drop you can run 235/35 front and 245/35 in the rear... No reason to stretch unless you will be running flush specs all the way around...You would need some serious spacers at an et40 offset...
nuldabz
09-03-2015 05:49 PM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
