tires
The Toyo T1-S is arguably the best tire for our cars.
Put mine on during the summer and they are fantastic!!!
215-50-17's will run you about $230-250 per tire CDN.
Do not compromise.
Go with this tire and you will not be dissapointed.
Do not compromise.
Dr. TLS
I'm thinking of buying the Pirelli PZero Nero M&S. They are rated #1 by Tirerack shoppers. Pilots are rated 3rd. Still, I read many of the personal reviews on the Tirerack site and one guy bought these tires and then replaced them with same kinds once the first ones wore out. I'm going with 235/45/17s on my stock TLS rims. They're cheaper than the OEM tires at $127 only. Here's the link to the tire: http://www.tirerack.com/tires/tires....omCompare1=yes
I didn't see the Toyo tires on that sight but the Pirelli tire seems pretty good. I guess I will buy The same size that came off my car 215/50/17just to make sure everything stays the same. Is it a better size tire to replace it with? I'm still not sure about the brand of tires though.....help
Dr. TLS
Originally posted by dmac
I just purchased a set of Pirelli P-Zero Nero M&S P225/45ZR17 for 128$ a piece.. Thanks for the comments.
They really do look like the best set of All Season Performance tires out there. I checked into bigger size and found that everything matches and there won't be any speedo error. DMAC, please post your review of your new tires as soon as you get the chance!
Thanks,
Tire Retard
I ordered the 215/45/17 tire, not the 225. They said it would be a couple of weeks before I got them because they are out of stock. Must be a good tire. When I get them I will let everyone know how I like them!!
tires
The stock tires was 215/50/17, I was hoping the Pirelli tires would be the same. The difference is I ordered 45 instead of 50 so it should be a little wider and not taller....right?
Re: tires
What you have ordered are tires whose sidewall is approx. 45% of it's width. A 215/50 series tire has a atio of 50% sidewall height to width. This accounts for the loss of about a 3/4 inch in overall height.
Look at the manufacturer's RPM (revolutions per mile) statistic regarding each tire. The closer that number is to the tire you are replacing, the closer they are in overall height.
Good luck, Ron
La Mesa, CA ....... where summer tires are your winter tires all year.
I think I made the wrong choice of tire size. I found a size calculator at http://www.discounttiredirect.com/di...foTireMath.jsp
Can anyone tell me more. I think the 235/45/17 will be my best choice. I hope it's not too late to change my order.
Thanks everyone. I will be going with the 225/45.
I wish I had, b/4 making a replacement tire decision.
The people in this forum a really fantastic. I see how erstwhile and honest they were in giving you the best advice they could muster and with some snese of urgency and candor.
Good luck with your new tires. And remember to post back how they are performing for you.
Quick question regarding tires. Will changing the tires significantly reduce road noise? The problem I'm having is that whenever I'm on the highway, there is a significant increase in road noise when I'm on concrete compared to asphalt.
I always thought the loud road noise was a Honda/Acura thing because our old '84 Honda Civic Hatchback was also like this. Will changing the tires to one of those recommended in this thread reduce the noise?
Thanks!
Thanks!
CostcoFanAUS
09-18-2015 06:05 AM
