Tire and rim size '04 TL
I have an 04 tl with the aspec kit. I got a guy that wants to sell me some 18inch msr rims with tire size 235/45/18. what are your thoughts on this? Will it rub?
It sounds like you have no idea what you're doing.
How wide are the wheels? Offset? Centerbore? Are you lowered? Are your fenders rolled?
As of right now, the tires are the wrong size. The sidewall needs to be 40 when you have 18" wheels on the TL.
Good to know. Find out the width, offset, and centerbore specs of the MSR wheels and we can help you more!
Here is the link MSR RACING WHEELS !!!!!!!
I guess the seller doesn't know the specs either
I would pass. Find someone who knows what they're doing; plus I like the stock wheels more.
bummer didnt show up lemme try again MSR RACING WHEELS !!!!!!! MSR RACING WHEELS !!!!!!!
Our bolt pattern is 5x114.3. If the two patterns on those wheels is 5x112 and 5x120, they won't fit.
Also, our centerbore is 64.1mm, so even if the pattern was correct, you would need rings to make sure they fit on the hub correctly.
ggesq (10-21-2014)
What you just posted totally contradicts what you posted 3 minutes ago. Make up your mind
Yes. They won't fit whatsoever. Wrong bolt pattern.
You're welcome! Don't rush into anything just because you think you're getting a good deal. Do your research and be as informed as possible. Proven by that Craigslist post, not every seller is legit or knows what they're doing.
For your future reference:
2004-2008 TL Stock Wheel specs
17x8
+45
5x114.3
235/45/17
Optional 2004 Gunmetal A-Specs
18x8.5
+45
5x114.3
235/40/18
Optional 2004-2008 A-Specs
18x8
+45
5x114.3
235/40/18
17x8
+45
5x114.3
235/45/17
18x8.5
+45
5x114.3
235/40/18
18x8
+45
5x114.3
235/40/18
The following 5 users liked this post by CLtotheTL32:
EL BAN (10-21-2014),
ggesq (10-21-2014),
jtmp456 (10-21-2014),
justnspace (10-21-2014),
Slpr04UA6 (10-21-2014)
ok so what do you think about these? im going to keep my stock wheels and tires just so you know but trying to go for a new look. the one that need repair i will fix or paint. thoughts and opinions please.
orlando - craigslist
Your link doesn't work.
It sounds like you're trying to change the look of your car the cheapest way possible. Speaking from experience, save your pennies and do it correctly. Cutting corners will only cost you more in the long run.
The following 4 users liked this post by CLtotheTL32:
Be a better driver
You shouldn’t be looking at wheels if you haven’t done your research, that’s an expensive mod to mess up. First learn about wheel/tire specs and how they affect everything, then play with wheel/tire calculators and figure out what setup will work for you. Then look for wheels/tires in the appropriate specs. Also think ahead if you plan to go lower.
Not really
You could try to find a set of Type-S or A-Spec wheels. They were made specifically for the TL so you won't have any issues.
hey guys a little help, im new to this site , I am trying to buy new wheels and tires for my 08 TL base model all stock, I was looking at Niche Milan, would these fit? do I have to do any modifications to my car /fenders, which of those to sets do yall recommend?
Size: Front 20x8.5 Rear 20x10
Bolt Pattern: 5x114.3/5x115
Offset: F +35 R +40
Bore 73.1
or
Size - Front: 19 x 8.5 / Rear: 19 x 9.5
Bolt Pattern - 5 x 114.3 ( 5 x 4.50 )
Offset - Front: +35mm / Rear: +40mm
Hub-bore to fit - 73.1mm
thank you
Offset: F +35 R +40
Bore 73.1
or
thank you
20s typically look too big on the TL, but that comes down to personal preference.
20x8.5 +30 will be fine up front. Run a 235/40/18.
20x10 +40 in the rear is pretty aggressive. I would suggest rolling your rear fenders and running 245/40/18 or 255/40/18 back there. Why do you want a 10" wide wheel in the back? Staggered looks great, but doesn't make too much sense on a FWD car. Doing that prevents you from buying the same size tires and also from rotating tires in the future to help tread life. Same goes for the 9.5" width you posted.
***The biggest thing to note is that the hub bore you listed is incorrect for the TL. Our car has a 64.1mm hub bore, while the wheels you posted are 73.1mm. Find a set that have the correct hub bore or buy hubcentric rings that ensure the wheel fits on the hub correctly.
Personally, I would buy four of the 19x8.5 +30 so they can be rotated. Run a 235/40/18 and buy 64.1mm to 73.1mm hubcentric rings. After that, consider lowering your car a bit and rolling the rear fenders.
So you bought them before doing any research?
From what I've found, the hub bore of the G37 wheels is 66.1mm, so you'll need 64.1mm to 66.1mm hubcentric rings.
No need to ask the same question in two threads.
You need to keep the same sidewall size for the front and rear.
Slpr04UA6 (11-02-2014)
Ok so I've heard 235/35/19 all around. But since the back rims on the g37's are wider shouldn't I get 245/35/19's in stead for the back? I'm buying the tires today just wanted a second opinion...................again.
Yes.
jtmp456 (11-03-2014)
g37 wheels to 04 acura tl
Longer front bumper? What?
