Tire Issue
Tire Issue
On my way to work this morning, I hit a pothole approaching the toll booths on I95. Wasn't that big of a hole, the hit wasn't hard at all and I was going well under 30 mph. About 20 mins later as I was getting off the highway, the car began pulling to the right, I got out and of course the tire was flat, luckily I was right next to a gas station and filled the tire right away. Of course there was a nice little bubble, and the tire split open right where the tread meets the sidewall.
My question is, given the fact that my car is only 2 months old, is there any way I might be able to get the dealer to replace the tire? I really don't feel like shelling out $200 for another POS el42.
there is no road hazard warranty on OE tires (from any manufacturer i know of). Costco includes a road hazard warranty on tires purchased from them. perhaps you should consider a set of 2 different tires (michelin?) now, and then add 2 later?
i would not buy another Turanza.
keep in mind you may have tagged/bent the rim, and you'll need to test drive (when the replacement is squared away) for possible alignment issues.
looks like:
tires 2x$200. = $400.
oe rim (used on ebay or take-off from dealer)
$150.
alignment $100.
put some more air in them , and stay away from potholes...
looks like:
$150.
alignment $100.
Check with the city where you had the tire damage due to pothole. In some instances city will compensate for replacement. Some cities do that, some don’t. I know of one city in IL that has policy that if you come with that complain and it has been yet another complain before, they reimburse you for replacement. It might be hard to get something from NYC though. Also, I am not sure about that policy on highways.
called the new york state thruway authority, and they gave me the runaround as expected. They are however sending me a claim form, which I expect will be denied, but it's worth a shot.
Anyone have a suggestion for a good all-season tire for a replacement?
I guess I'll replace the 2 front tires, after hearing all the negative stories about the turanza, I'm not sure I want them on my car for the coming winter.
tire damage
My car was only 1 month old when it happened to me. I called my dealer and bugged them really bad. They replaced the tire for me. I also tried to get them to replace all tires with different ones. They were going to give me the EL42's.
So i called michelin and bugged them about the issue. They were willing to pay 1/2 of the new tires in which they did. I got the Pilot Sport A/S and they are great. I ve hit a couple of potholes and nothing!
Hope this helps you out!
You called Michelin? Why would michelin get involved when you're having a problem with the Bridgestone Turanza?
WDP Director of R & D
--Dealer probably wanted to swap his Michelin's with EL-42's... Now theres a good deal.....
Ganz
Tires I have become fond of are Pirelli PZero Nero M&S and the Bridgestone Potentz RE950. Obviously, I am an all season radial fan.
but, do as other have suggested and go to tirerack.com and do the research, read the surveys, and pick what you like.
Good luck.
Good luck.
cycdaniel
12-17-2019 10:58 AM
