Are there A-Spec wheels available in 19" or 20"???
Anbody know if Enkei or whatever manufacturer will make the factory OEM A-Spec wheels in 19" or 20" instead of the current 18"? I think they look great in chrome or sparkle but I'd prefer a bigger wheel, maybe even wider than the current 8" or 8.5" width.
the RDX wheels should fit, but maybe with a spacer as the factory offset for the TL is +45 and the RDX is +38. the RDX has a bolt pattern of 114.3 x 5 like the TL to my knowledge. I am sure a local dealership would let you try one out for test fitting without a tire.
I saw someone put this rim on an RL... and it didn't look right... the wheels pop outside of the wheel arch and doesn't flush completely with the body... if that happened to an RL, I can imagine that won't go too well with the TL
94 DC4 RS LSV/Turbo
^ the last 2 need to lay off the duby
A +38 offset would still leave about 8mm of clearance and would look nice
The RDX rims bolt pattern coincides with the TL it won't with the RL since the RL is 5x120....
In other words... the rl wheels fit no problem (but I bet you they are heavy as fuck)
If you like the look check out the ASA ST4 or the Sport Edition ST4... or the Ronjon Devotions....
EvilVirus
12-10-2015 07:38 PM
nuldabz
09-03-2015 05:49 PM
