Stupid offset question
Old Aug 12, 2001 | 07:03 AM
TorontoTL's Avatar
Sorry guys for asking and sounding stupid, but will a 17X7 wheel with an offset of 45+ with215/50-17 tires fit the 2000 TL without rubbing or fitting weird? I have the OEM suspension.
Also how about a 17X7.5 wheel with an offset of 50+ with the same 215/50-17 tires.
Which would be better on the TL?
Old Aug 12, 2001 | 06:19 PM
Lawaia's Avatar
Moderator Alumnus
Several guys (including myself) have been successful mounting 215/50-17 on a 17x7 with +55 offset wheel with no rubbing problem whatsoever. The same wheel with +45 offset will move the tire outwards .4" which should be ok given your car isn' dropped.
17x7.5 with +50 offset will have almost the same results as above. Except the inboard extension will increase .05".
Good luck!
Old Aug 12, 2001 | 07:41 PM
TorontoTL's Avatar
Smile
Thanks for the reply. In fact you have answered another question I was going to ask. I found another wheel that I like, it's a Team Dynamics called Diablo, it's a 17X7.5 with a +50 offset and I was going to put Michelin Pilot XGT H4 215/50/17's on them. I hope that would be fine as well. Do you think that would be okay too? Do you think there would be any rubbing?
Old Aug 13, 2001 | 02:18 AM
Lawaia's Avatar
Moderator Alumnus
Shouldn't have a problem given the difference being a mere .05" inboard increase. There are guys here that have successfully equipped their rides with 8" width rims with no problems, other than trimming a bit of plastic here and there. You should be fine.
Old Aug 13, 2001 | 11:57 PM
NighthawkBlack's Avatar
Where is the offset written?
Old Aug 14, 2001 | 01:05 AM
Lawaia's Avatar
Moderator Alumnus
The offset is stamped on the inside spoke on the factory rims. Not sure about after-market wheels.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
KBTypeS
25
Oct 1, 2015 04:49 PM
navtool.com
Sep 25, 2015 05:15 PM
